64 f250
Old Aug 13, 2011 | 03:34 PM
jfrank8103's Avatar
jfrank8103
64 f250
ok ive been trying to figure out a way to lift this truck its only 2wd and ive seen plenty of them lowered just want to do something different. also im need hepl figuring out how to adjust the clutch too
Old Aug 14, 2011 | 04:39 PM
CTom's Avatar
CTom
Should be pretty easy to put blocks between the spring pack and the axles.............Lots of newer trucks do it that way.
Old Aug 15, 2011 | 12:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jfrank8103
I need help figuring out how to adjust the clutch.
Welcome to FTE
The clutch adjustment rod attaches to the clutch equalizer (aka Z) bar, has threads on one end.
The threaded end has a nut, there is a round conical shaped threaded spacer that fits to the backside of the clutch fork...that has a round hole in it for the spacer.
The spacer threads onto the rod, tightning it adjusts the clutch, then the nut on the threaded rod is then tightned up to the spacer to keep the clutch in adjustment.
Illustrated here: 1964/72 Ford Truck Parts Catalog / Illustration Section 75, Page 1 (This catalog is available on a CD from hipoparts.com for 22 bucks).
Old Aug 15, 2011 | 09:00 AM
jfrank8103's Avatar
jfrank8103
1964 F250 2wd
just want to make sure that if i put lift blocks in the front of this truck that there not going to break cause i know on the 4wd its not recommended
Old Aug 15, 2011 | 01:07 PM
CTom's Avatar
CTom
They have to be a reasonable size........I have made blocks from one inch aluminum stacking 2 together, worked fine. Spring shops will sell you u-bolts any size you want.
Good luck.
Old Aug 15, 2011 | 08:44 PM
jfrank8103's Avatar
jfrank8103
64 f250
ok i was looking for 2 inch blocks didnt want to go to big just wanted to make sure i didnt break anything cause i found some made out of cast iron or something i know its not aluminum
Old Aug 15, 2011 | 10:38 PM
Bill W's Avatar
Bill W
I lifted my 63 f250 in the front. first thing is take the leaf springs out and find a shop to re-arch them. 2.5 inches is all you can go without any mods to the spring eyes. (making a new top leaf)
from there i made my own 2" blocks from reciver hitch material got a long leaf spring center bolt and ran it all the way through the block and springs. you will need to mod (Z)the drag link if you go more than 2 inches. i had the spring shop make me 2.5" longer U bolts
if you want pics i have some.
M1kem3
Feb 27, 2015 12:19 PM
bert cook
Feb 23, 2013 01:29 AM
mdacton
Jan 2, 2011 09:31 PM
fisheasy
Apr 1, 2009 10:05 PM
wibblequikit
Aug 8, 2007 07:16 AM
