Negative Cable...
Old Aug 12, 2011 | 01:36 PM
ozark1's Avatar
ozark1
Negative Cable...
After cleaning and painting the battery area on my '84..I see the negative cable is ready to replace.. I have a length of new proper battery cable..,and some brass ends.... but how do I make the connection on the frame where the tab holds the cable ?..I know it grounds there, and on the starter bolt. Is it just a metal to metal contact..held by the tab ?...
Old Aug 12, 2011 | 02:02 PM
Archion's Avatar
Archion
Veteran: Marine Corps
The original that piece is crimped onto a spot where the insulation is stripped. Most people usually just make it two cables and use that bolt as a junction point
Old Aug 12, 2011 | 02:09 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Correct. Metal to metal contact on the tab to the wire cable itself.
What I usually do is remove the tab from the old cable, and cut the insulation off the new cable in the right place, and crimp the tab on the cable. Then use shrink wrapping and/or electrical tape to keep the connection clean.
This gives a factory looking replacement.
marksman76
Apr 29, 2019 02:52 PM
ms1780
Dec 7, 2018 08:31 AM
earnies2
Jan 21, 2006 03:47 PM
ggirten
Jan 10, 2006 11:35 AM
jimberg
Oct 20, 2004 03:05 PM
