General Diesel Discussion
Volkswagon TDI
Old Sep 14, 2011 | 06:11 AM
Rose Clifford's Avatar
Rose Clifford
Originally Posted by bent-1
Check out this forum before you buy:
TDIClub Forums - Powered by vBulletin
Regarding Passat TDI's (03-05), there's a ticking time bomb in the balance shaft chain system, it's the automatic adjuster/follower. They have a history of failure 60k-80K. The oil pump is driven off this chain. The upgraded system is gear driven (a VW service upgrade) that costs north of $2500 (including labor).
Glad I had mine done as it was shot when pulled at 90k. Amazingly the chain didn't pop off the gears or the motor would have been toast.
Too late, I got a 2011 Jetta TDI, first fill up I got 41.7mpg
Old Dec 5, 2011 | 06:27 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I have a 2004 TDI Jetta BEW. I bought it new in 04 and have 176,000 mi on it. I range from 38-42 mpg but usually closer to 42.
I just performed my second timing belt change and went ahead and changed out my cam and followers this time due to premature wear on the exhaust lobes. Overall it wasn't too bad of a job. It runs like a sewing machine.
Besides my 06 PSD CC FX4, it has been the best vehicle I have owned.
I just wish we had a dealership that was worth a back flip!!
Old Dec 5, 2011 | 08:41 PM
dagren99's Avatar
dagren99
The timing system is one of the few weak spots on the TDI. (VW's in general - the 2.0 gasser's timing belt is also a known prob) One other is the front strut mounts - our Jetta is on its 2nd set of strut mounts @ 160k. The OEM ones were gone @ 90k - got 70 so far on the replacements.
Old Dec 5, 2011 | 09:13 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I put Koni Reds on mine around 145,000 and they are great. They are adjustable so when they start feeling soft I can tighten them up. I don't remember the mounts being wore out tho...
Old Dec 6, 2011 | 05:41 AM
Rose Clifford
The timing belt intervals were upped to 120,000mi on the 2012 and 2011's
Old Dec 6, 2011 | 06:45 AM
dagren99's Avatar
dagren99
The interval for changing the timing belt seems to vary depending on who you ask. Some say change it @ 80K others say you're ok till 100k - did find that VW has 2 different p/n's for the timing "kit" - they made changes in 03-04 that extended the life out to 120k. Found this out on the VW forum but when I asked a dealer about the 2 pn's they said their was only one and it should be changed. @ 75k. I ended up getting the parts online and doing it myself - changed to the metal impeller WP at the same time.
Old Dec 6, 2011 | 06:48 AM
Rose Clifford
I'm saying there's a different belt in the 2011+ models
Old Dec 6, 2011 | 06:54 AM
dagren99's Avatar
dagren99
There's also 2 pn's for the older models - VW made an "upgrade" so they'd last longer. Anyone with an older TDI should upgrade to the new pn so it won't have to be changed out as often
Old Dec 6, 2011 | 06:55 AM
Rose Clifford
Exactly. I *THINK* these are referred to as the teflon coated belts. I'm sure Dan (kwik) could shed some more light on the subject
Old Dec 6, 2011 | 07:01 AM
dagren99's Avatar
dagren99
Its been a couple of yrs since I did it but I recall something about the tensioner is different too. This was well covered ovr in the the VW forum.
Glad we don't have to deal with this kinda thing on the Ford side. Changing one is a PITA!
Old Dec 6, 2011 | 08:55 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Knowing the damage that occurs when the TB breaks on these non clearance engines, I wouldn't go over 100k regardless what they say. That is flirting with disaster!
Old Dec 7, 2011 | 06:54 AM
dagren99's Avatar
dagren99
Yeah breaking one = engine rebuild for sure. Seems like they are unpredictable - some folks go way out to 120K and the belt looks great or they go @ 80-90 and trash the engine. Earlier 00-01's seem to have be the worst ones but VW didn't really make it any better until just recently. We have an 03 that went 110K on it's original belt and it looked great but I've learned that's not a good indicator because: I did a timing belt "inspection" @ 80k on another VW and it looked great - problem was it failed 4k later.
Old Dec 7, 2011 | 08:15 AM
  #28
Shaneb75's Avatar
Shaneb75
Strokin Okie
Exactly! I read a post recently where the belt was still intact, but had several teeth stripped off. Thats why I just dont trust TBs, or what they recommend the change intervals to be. For me it will get done between 90-100k, and I may still be streching it a bit...
They are still great vehicles. What other car will cruise down the road @ 80 mph and still put out 42mpg? BTW I live in turnpike country so 80 isnt speeding too much...
Old Dec 7, 2011 | 08:28 AM
  #29
dagren99's Avatar
dagren99
We love our 03 - gets 40+ mpg most of the time and has been relatively trouble free save a few small things. Big thing for VW's - STICK to the maintenance schedule! - if VW says to do it - do it no later than what they say and preferably earlier. Brake fluid changes are another big one - neglect the 2yr change interval and you'll prob have a line rust from the inside out a year or 2 later.
Old Dec 7, 2011 | 09:08 AM
  #30
Shaneb75's Avatar
Shaneb75
Strokin Okie
My VW is the reason I bought my Mityvac. I flush everything I can get my hands on.. lol.
I have an 06 Powerstroke, so I have 2 vehicles I cant skip maintenance on.... :/
