cab leak
Old Apr 1, 2003 | 10:28 PM
Boss300's Avatar
Boss300
cab leak
My F100 has been leaking water into the cab on the passenger side from somewhere under the dash since it was almost new. I cant really tell where it is comeing from. Has anyone had this problem? Could it be the windshield or is it coming from the water vents in the cowl?
Thanks again
Josh
Old Apr 1, 2003 | 10:38 PM
MW95F250's Avatar
MW95F250
cab leak
Check your heater coil. That is usually a symptom of a good heater coil gone bad.
Old Apr 2, 2003 | 02:23 AM
oldfordtrucksrule's Avatar
oldfordtrucksrule
cab leak
your windshield is probably leaking. mine was until i used some windshield sealer from auto zone. it worked good.
Old Apr 3, 2003 | 11:11 PM
steve83's Avatar
steve83
cab leak
If it's not engine coolant or condensate from the A/C, then it's either the windshield or the seal around the heater core pipes where they penetrate the firewall. Some caulk or butyl sealant (Tacky Tape) will fix it.
Old Apr 5, 2003 | 12:53 AM
Boss300's Avatar
Boss300
cab leak
Thanks for the replies. I have never heard of windshield sealer available at parts stores. What is it and how do you use it?
Thanks
Josh
Old Apr 5, 2003 | 08:27 PM
Franklin2's Avatar
Franklin2
cab leak
I have used that stuff from advance auto with good success. It's just clear silicone that is very runny so it flows down behind and next to the trim to seal it off.
Old Apr 5, 2003 | 11:56 PM
steve83's Avatar
steve83
cab leak
You should pop the trim off before applying any sealant, then reinstall the trim.
64rednwhite
17
Mar 10, 2014 10:00 PM
LordZamize
2009 - 2014 F150
29
Apr 4, 2013 05:22 PM
Ford Blue
Feb 3, 2005 07:00 AM
fishman5758
1997 - 2003 F150
13
Nov 21, 2003 10:21 PM
93bigbronco
1978 - 1996 Big Bronco
Dec 17, 2001 11:43 PM
