And youall probably already know this, but for some of the newcomers, DON'T ever perform a "wet" compression test on a diesel engine. This is where you squirt a small amount of motor oil into the cylinder to better seal the rings - the difference between the dry reading (taken first of course) and the wet reading can help to determine how worn out the rings are.
On a diesel, if you add oil to the cylinder, it can act as fuel and blow up the compression tester. In your face. Not good!
As far as the OP's compression #s, you're golden! It's more of the difference between cylinders that counts, but on a diesel you want to see usually at least 350 lbs or higher.
