spark plugs question
Old Aug 11, 2011 | 04:52 PM
mrdakotaman's Avatar
mrdakotaman
i have a 400 it was told it is stock, with bout 5000 miles. nothing wrong with it i drove it for 1000 miles just wanted more power, while i started to pull it down and i see that it has ac delco plugs r45ts which is the same as a 26 autolite, the truck calls for a 25 why would you want it hotter than stock, now ive put a lunati vodoo cam 62501, springs retainers, pushrods, weiand 8010, and a carter 625cfm, and easied the edges in the ports of heads, wwhat plugs would u recommend, on my harley with motor work they always went 2 ranges colder, i was thinking just stock plugs in this application. thanks mike
Old Aug 11, 2011 | 09:07 PM
400inatruck's Avatar
400inatruck
With the cam and the bigger carb, run some just like the ones you got, or a step hotter. be careful tho. play around with the ignition timing.
43Duc
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Mar 16, 2008 11:22 AM
nickmobile67
General Automotive Discussion
Dec 29, 2005 11:59 PM
oldgoat49
1983 - 2012 Ranger & B-Series
Oct 1, 2005 03:36 PM
royharper
Aug 25, 2004 05:42 PM
broncr
May 11, 2003 10:40 PM
