Sponsored by: Real Truck
Big problem
Old Aug 10, 2011 | 08:43 PM
dabigo1's Avatar
dabigo1
Big problem
My 08 F-350 had the Engine lock-up and ford couldn't find the problem after a week in the shop and $600 later, I towwed it home and tore the engine out myself and I couldn't find any thing wrong until! I took the high presure fuel injection pump out and now the engine turns great, However $1169.50 from Ford for a pump. I would like to find one a little cheaper....HELP!!!!
Old Aug 10, 2011 | 09:45 PM
jh818's Avatar
jh818
Wouldn't it still be under warranty?
Old Aug 10, 2011 | 11:47 PM
dabigo1's Avatar
dabigo1
No the truck is out of extended warranty, it has 116k
Old Aug 11, 2011 | 02:30 AM
parkland's Avatar
parkland
I believe you need to replace more than just the pump.
Old Aug 11, 2011 | 06:40 AM
senix's Avatar
senix
You probably can get the stuff sent to you from www.partsguyed.com cheaper than the local dealer.
Do you have the repair manuals? If so they should also indicate replacement of some of the fuel lines and stuff for the injectors if removed them. So yes you will need more than just the pump probably.
Did you do the cab off method or just torn it apart with the cab on?
woody367
Sep 22, 2017 11:35 AM
Spktyr
Sep 16, 2016 10:27 AM
Rich302
6.4L Power Stroke Diesel
Sep 20, 2013 08:52 PM
Jefff H
6.7L Power Stroke Diesel
31
Oct 24, 2012 08:07 AM
blackout150
Feb 15, 2012 05:37 PM
