6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
here's one for you
Old Feb 13, 2012 | 06:12 PM
blackout150's Avatar
blackout150
here's one for you
My brother-in-law has an '08 F450 diesel. I got a message from my sister a couple weeks ago asking if we had $17,000 she could have (in jest). I said uh-oh, what did he do now? Apparently, the fuel pump (? I wondered injector pump, but she said no) blew/disintegrated, and in turn sent all kinds of wonderful minute particles into the engine and therefore destroyed it too. Of course he has 140k on the odometer so there is no warranty. I searched the net and have not come up with another instance of anything like this. Anybody ever heard of anything like this at all? I would think this is a defect in the pump to cause something like this, but what possible recourse could he have at this point? He loves this truck, it's his second SD, but he has issue after issue. Luckily, the other problems he has had were covered when it was under warranty. He also has the issue of having some sort of bullseye on him that everyone but him can see, as he has been hit numerous times in both of his SD's. At this point he is looking at $12k to have the engine replaced and is not happy at all.
Old Feb 13, 2012 | 07:10 PM
edjunior's Avatar
edjunior
That's the first time I've heard that one. And since it's out of warranty, I'm afraid he's stuck. Bummer.
Old Feb 13, 2012 | 07:57 PM
kd0axs's Avatar
kd0axs
That really sucks. Unfortunately, he is stuck with it being out of warranty. I'm no diesel expert, but I would think the fuel filter would catch stuff like that.
That's one of the things that has made me stick with gas. If for some reason my engine does go, it's a couple grand and I can replace it myself.
Old Feb 13, 2012 | 08:11 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea how did it get past the fuel filter ???
Old Feb 13, 2012 | 08:15 PM
F350-6's Avatar
F350-6
The high pressure fuel pump is downstream from the filter. The pressures developed are too high to put a filter between that pump and the motor. It would shred the filter.
We've read of similar occurrences on the 6.7 diesel as well. Apparently those pumps don't like any form of water in the fuel at all.
Old Feb 13, 2012 | 08:20 PM
kd0axs's Avatar
kd0axs
And that's why I'm not a diesel expert.
Makes sense though.
Old Feb 13, 2012 | 08:26 PM
ABF PSD's Avatar
ABF PSD
I have heard something like this happening to 6.4s. It was in a video done by Bill Hewitt from powerstrokehelp.com. I saw it on youtube i think. What he explained was that either regular gas or water will make the HPFP internally explode and send all that junk to the engine via the injectors. He had one disassembled and showed all the little pieces. I will try to find the video and post a link to it.
Old Feb 13, 2012 | 08:40 PM
dualwheels66's Avatar
dualwheels66
If it was me, I would invest that 12k in a Cummins swap. How about your insurance company, will they cover that?
Old Feb 13, 2012 | 08:42 PM
critterf1's Avatar
critterf1
That really sucks!
Old Feb 13, 2012 | 08:47 PM
kd0axs's Avatar
kd0axs
Not unless it happened as the result of some sort of unfortunate "accident". I don't recommend committing insurance fraud though.
Old Feb 13, 2012 | 09:15 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.4L Power Stroke Diesel forum.
Old Feb 13, 2012 | 09:50 PM
StanleyZ's Avatar
StanleyZ
I don't want to say it's common but it does happen. Sometimes the culprit is water in the fuel. If that's the case there is a chance of collecting from the source of the fuel, or more likely on the comprehensive insurance. I have no idea what proof the insurance company would want. If a Ford dealer has the truck maybe thy can provide evidence that the pump imploded due to water in the fuel. If you look through the 6.4L forum you should find a couple other cases like this. Maybe you could ID the poster and PM him for more detailed info. Good luck
Old Feb 14, 2012 | 07:02 AM
SANDDEMON08's Avatar
SANDDEMON08
Worst case if the auto insurance angle doesn't help a more reasonable fix might be a good used take-out engine. Ive seen allot of them on e-bay with 15,000 to 50,000 thousand miles for 3,500 to 6,000, there usually salvaged trucks but the engine come with some type of warranty. The engines come complete with turbo,fuel,system,harness...ect basically a drop in.
Old Feb 15, 2012 | 05:22 PM
blackout150
When I talked to my sister yesterday, she said they are hoping there are signs of water on the inside of the pump. I guess that is the proof the insurance wants to be able to file a claim. I have no idea if any rust would show up in there or not. I would think they could have the fuel in the tank tested, but maybe that isn't good enough. He had just drained water out of the separator (?) about a week before this happened. Keeping our fingers crossed. I had no idea something like this could happen, pretty amazing, but downright terrible.
Old Feb 15, 2012 | 05:37 PM
senix's Avatar
senix
When you pull the top filter, use a camera and flashlight and take some pics. Rust and metal shavings...also keep the filters. Probably there too. Insurance may want them.
diagnosis from the tech should be good enough to get the ball rolling for the repair
chris023
Jan 19, 2017 04:53 AM
Watcher58
Mar 1, 2016 07:59 PM
F16Vip3r
6.7L Power Stroke Diesel
May 18, 2013 04:43 PM
Jefff H
31
Oct 24, 2012 08:07 AM
frdfan
17
Dec 11, 2011 11:03 PM
