replacement starter
Old Aug 10, 2011 | 08:30 PM
crsmiffy's Avatar
crsmiffy
replacement starter
gentlemen, I am in the market (soon as money allows) to replace the starter on my 400-C6. It is the old rat trap type and on a bit of a strip down when the engine was reguilt it is seriously on the way out. The armature and brushes are both well worn and I believe it is the original from back in 72. I will be fitting headers as the OEM cast log units have been cracked/repaired before and are on their way out.
So between the worn starter (still starts ok for now!!) and the clearance I need to get the headers through I would like a smaller one so a gear reduction one would be the go.
My problem is I don't have a lot of money to play with (who does) so the obviously good ones like CVR at $300 plus are a toughy to swallow. They have them here in Australia as well as a local who makes a very similiar unit i.e. indexable, small and gear reduction as well as the price albeit a tiny bit cheaper. There seems to be a very limited market for the 400's in the cheaper starters. Bucketloads for the Chev's and Windsors but the clevelands and 429/460's are very few and far between. The wreckers over here are no good either. We just don't have the massive amount of F-trucks over here to rob an applicable starter off and I have been told they just don't have them.
I have been looking on evil bay and there is an outfit called Alterstart (Texas?) that do a cheaper alternative approx $130US. for around $40 to get it here to Aussie, a $180 starter would be not to bad. Warranty would be problematic so thats the reason for this post. Alterstart any good, or are there any other alternatives? Cheers.
Old Aug 10, 2011 | 09:55 PM
ctubutis's Avatar
ctubutis
Do you have somebody down there who rebuilds electric motors and can rebuild yours?
BTW do me a favor, hit User CP in the top-left and finish filling out your profile so we can see where you're at.
Old Aug 10, 2011 | 09:58 PM
crsmiffy's Avatar
crsmiffy
I'd rather not rebuild mine as a I could do with the room for the extractors etc.
Old Aug 10, 2011 | 10:18 PM
crsmiffy's Avatar
crsmiffy
No worries had a crack at the CP just then. Still a noob at this stuff.
Old Aug 10, 2011 | 11:17 PM
ctubutis's Avatar
ctubutis
Thanks for the profile stuff.
I see you have a Facebook button but it doesn't work. Mine didn't at first, either, had to get into the Facebook preferences and set up an externally-available URL, then plug that into the FTE thing.
Old Aug 15, 2011 | 08:51 PM
crsmiffy's Avatar
crsmiffy
no more help from any-one on these starters??
Old Aug 15, 2011 | 10:21 PM
ctubutis's Avatar
ctubutis
I've seen the gear-reduction things talked about out here on FTE but can't remember exactly where.
You might also ask in 80-86 and 73-79:
1980 - 1986 F100, F150 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
1973 - 1979 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Old Aug 15, 2011 | 10:48 PM
crsmiffy's Avatar
crsmiffy
Thanks. I'll let this go for another day or so now it's been bumped and then try those other jobbies. Cheers
gray035
20
Nov 8, 2016 01:26 AM
BruteFord
28
Aug 20, 2014 12:33 PM
Automator
17
Aug 15, 2013 02:42 PM
crsmiffy
Sep 7, 2011 12:48 AM
1977 Explorer
Nov 4, 2009 09:41 PM
