u joint replace job
Old Aug 10, 2011 | 06:23 PM
turbill's Avatar
turbill
u joint replace job
As some of you know my trucks in a shop right now (has been forever). I'm finally at a shop that knows older trucks and suspension/4X4 stuff. But they told me they found my passenger side u joint is worn and should be replaced.Its not related to the accident so insurance wont cover it so I'd like to fix it myself.
Who's done this and how bad is it. I have a D50 and i know i'll need to rent a ball joint press. but what else is involved and is this a job for a garage mechanic
Thanks in advance
Old Aug 10, 2011 | 07:23 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Its not as bad as the middle one obviously but still a job. Ive only done a couple one was a royal pain but the other came apart about like you would expect.
Old Aug 10, 2011 | 07:33 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
its not one of the funner jobs but not as bad as replacing the ball joints.
yeah,it's for sure something you can do yourself and save lots of $ though.
it's a good idea to do both outer wheel U-joints at the same time.if the center seems ok,then leave it alone.it's harder and doesn't ware as much as the outer's.
Old Aug 10, 2011 | 10:09 PM
84-6.9L's Avatar
84-6.9L
Its not hard at all, you will need a 6 tang wheel bearing socket, but thats really about all the special tools you will need.
Old Aug 11, 2011 | 02:24 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Make sure you replace all the seals! I replaced all of them but the inner ones and 2 days later i found puddles at either end of my axles. I had a whole mess of parts i replaced at the same time and totally forget them.
Old Aug 11, 2011 | 06:53 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/9...-u-joints.html
Here is a link to a good writeup. You would not have to go as far as the ball joints.
Old Aug 11, 2011 | 07:39 AM
mechelement's Avatar
mechelement
I've done it. IIRC, you can choose to only replace your outer u-joint since there's a slip joint on that long side. You have to pull your hub and disconnect the steering from the knuckle to get it out. Since you'll be in there, you should consider doing all three u-joints. One side is clipped in which requires pulling the front diff. Perhaps you could replace the u-joint w/o pulling the axle. If you pull the axle out of the diff, you could run into an inner axle seal leak after you button the front end back up and you'll be pulling it apart again.
Old Aug 11, 2011 | 08:34 AM
84-6.9L's Avatar
84-6.9L
I have done this on 3 trucks and never had a seal leak, I just put some grease on the end of the shaft and carefully slid it though, maybe I get lucky.
Old Aug 11, 2011 | 10:44 AM
turbill's Avatar
turbill
thanks for the insight guys that write up answered a lot of my questions it doesn't seem as bad asi thought it was but i'm still not looking forward to it i'll update you on how it went but that wont be for at least a week
Old Aug 11, 2011 | 06:51 PM
FORDF250HDXLT
same here.
so far,iv yet to ware out the inner on my last truck,and this one.the previous trucks before that where 2wds.anyway like you,iv never had any issues with just sliding the pass side axle back in.
Old Aug 12, 2011 | 06:48 AM
mechelement
I replaced my inner axle seals/bearing when I rebuilt the front end because both sides were leaking. My PSD's inner axle seals leaked after I did ball joints and u-joints. That was a real PITA.
Old Aug 14, 2011 | 10:47 AM
tecgod13's Avatar
tecgod13
Turbill, if you're on my side of the state (western) when you do this, I do have a shop press in my garage and can give you a hand.
I'd spray them down with some penetrating oil a few times to loosen things up a bit. Should make it a little easier when you tear it apart.
Old Aug 17, 2011 | 06:12 PM
whenry912's Avatar
whenry912
Where are y'all at in Western Mass? I am moving to Agawam soon and have a whole bunch of tools and would be more than willing to lend a hand!
Old Aug 18, 2011 | 12:25 AM
turbill's Avatar
turbill
i'm in southwick right next to Agawam. But i might be putting the job off because i'll be going back to school and leave the truck at home so i'l pretty much never be driving it. so i might leave it till December when i'm back and need the truck again
Old Aug 18, 2011 | 08:58 AM
whenry912's Avatar
whenry912
Oh that's pretty close. Ok, well good luck at school!
jeep_guy48
Sep 28, 2014 03:53 PM
fridgeddiesel
Jul 5, 2009 08:02 PM
Pilgrim
May 27, 2005 11:01 PM
96fourbanger
Jan 13, 2005 04:50 PM
matt77F2504x4
24
Sep 6, 2004 07:22 PM
