Distributor wobbles
Old Aug 10, 2011 | 11:41 AM
nlareau's Avatar
nlareau
Distributor wobbles
When I put my hand on the distributor I can feel a slight, but definite, wobble. 77 4.9L I6.
Ignore it, or worry about it enough to replace it?
Old Aug 10, 2011 | 02:28 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I would investigate it further for sure. Make sure it is seated properly and whole housing isn't moving. Pull the cap off and check for side to side movement. Also check the contacts in cap for signs of damage. Worn bushings will cause that and usually show up as a miss you can't track down. Could be the springs holding the cap on are weak and allowing the cap itself to move.
rustywheel68
Nov 27, 2015 11:13 AM
NICKSAN
13
Oct 10, 2015 03:04 PM
Tom Dowdell
Jul 30, 2009 11:14 PM
jon69f250
Sep 10, 2001 09:36 AM
