1978 - 1996 Big Bronco
Will this tranny work??
Old Apr 1, 2003 | 08:42 PM
ford racer 02's Avatar
ford racer 02
Question Will this tranny work??
I have been looking at a C-6 out of a one ton van that had a 351W in it, and this C-6 transmission should work right, it says it has the same bolt pattern and stuff but will it with the tail shaft and stuff, the van was 2WD
Also the A/C in my bronco hasn't been working, when i charged it with 134 A/C Refridgerant, it started kicking on and off, i know this is because it is low, but is there anything else to look at??
Old Apr 3, 2003 | 11:52 PM
steve83's Avatar
steve83
You need a 4WD transmission, or you'll have to have that C-6 rebuilt & converted to 4WD so you can mount the t-case to it.
There are a lot of things you have to do to convert to R-134a successfully - check the HVAC forum for more info.
Jmanb13
Jan 6, 2016 01:28 AM
tabijan
Sep 2, 2015 03:57 PM
Truckerswife
Jul 26, 2015 04:25 PM
Odisvan
New Member Introductions
Jul 2, 2015 02:13 PM
quinttheman
Aerostar
20
Jul 21, 2006 12:24 AM
