1978 - 1996 Big Bronco
Dies in reverse
Old Aug 10, 2011 | 03:13 AM
Jax Rhapsody's Avatar
Jax Rhapsody
Dies in reverse
Sometimes if I sit in reverse long enough, my Bronco will die. Like between two and 5 minutes. It's not a problem for me, I'd just like to know why.
Old Aug 10, 2011 | 11:42 AM
Encho's Avatar
Encho
The Southernmost Mod
I get you own an auto, right? i'm having the same issue, but mine stalls the second i put it in reverse if i don't touch the gas. I'm thinking it's a TPS issue, and i will be replacing it soon, so i'll let you know.
Old Aug 10, 2011 | 01:40 PM
Kemicalburns's Avatar
Kemicalburns
give us info on your rig, like year, motor, tranny etc..
probably time for a service
Old Aug 14, 2011 | 05:33 PM
Hizootiemizark's Avatar
Hizootiemizark
Does it have any idle problems like surging low or high? I had the same problem and found out on here I could clean the IAC valve and solve the problem. Cleaned it with electrical cleaner ($4 aerosol can at wal mart). Its been fine for over a year. Search IAC valve might help.
Old Aug 16, 2011 | 04:34 AM
Jax Rhapsody
88 Bronco, C6, 351W
Old Aug 16, 2011 | 10:28 AM
Kemicalburns
could be a few different things. check for the basics like a vacum leak, spark issue or perhaps a fuel pump/filter issue.
that year should be efi so perhaps pull codes
Old Aug 16, 2011 | 07:26 PM
mrv8outboard's Avatar
mrv8outboard
4wd High
I know it is going to sound funny but check the tranny fluid level. It is more of a problem with the AOD's but I had a 1996 5.8 in the shop with a stall at lights and going into reverse. Filled the transmission to the full line and it was all good. It has to do with the load/free wheel and IAC response timing.
Old Aug 17, 2011 | 09:51 AM
FLCrackerTracker's Avatar
FLCrackerTracker
This....mine did the same thing....added tranny fluid...never stalled again after.
Old Aug 17, 2011 | 10:37 AM
Encho's Avatar
Encho
Hmmm... that could be a posibility, since my tranny is leaking, i'll have to check on that...
Old Aug 21, 2011 | 02:39 AM
Jax Rhapsody
Yeah, I haven't tested it yet but it was a quart low. Eventually all ignition stuff will be replaced. It's gonna be hell doing the injectors though.
jecp
Escape & Escape Hybrid
Aug 23, 2017 09:12 PM
TexasGuy001
16
Feb 8, 2012 03:39 PM
Encho
Mar 25, 2011 01:07 PM
crestfallinman
Sep 9, 2009 08:48 AM
1998XLT
1983 - 2012 Ranger & B-Series
May 22, 2002 02:44 PM
