clicking noise
Old Nov 11, 2005 | 09:02 AM
JaredP's Avatar
JaredP
clicking noise
I have a 98 ranger 2.5 standard and it had started to make a clicking noise at high rpm but now it has progressed and now even makes this noise when I am idling in neutral. It sounds like it is coming from underneath the cab of the truck. Can somebody give me any ideas what to look for? Thanks
Old Nov 11, 2005 | 04:12 PM
natebaker's Avatar
natebaker
Check the tensioner pully. I have the same motor and that's the next replacement for me. The way to tell is to get a really long screwdriver, extension or something of that sort, put the end of it on all of your pullies and put your thumb over the end. Put your ear on your thumb and listen for a grinding noise. You'll hear a normal, consistent grind on most, but if you hear any sort of surge or fluctuations, that may be the culprit.
Old Nov 11, 2005 | 05:19 PM
big6-87bronco's Avatar
big6-87bronco
It almost sounds like it could be an exhaust leak. Get under your truck like natebaker said to see if you can pin point the location of exactly where it is coming from.
Old Nov 13, 2005 | 09:13 AM
JaredP's Avatar
JaredP
Smile
Hey thanks for the info. It helped! Now I just need to fix it. Thanks again!
Old Nov 15, 2005 | 12:57 AM
JaredP's Avatar
JaredP
it was a leak in the exhaust. Thanks!
Old Nov 15, 2005 | 08:14 AM
big6-87bronco
Glad to hear that it was not a major problem.
TheProfessorofTOOL
1997 - 2003 F150
Dec 26, 2013 08:15 PM
TheProfessorofTOOL
1997 - 2003 F150
Dec 26, 2013 04:01 PM
posthumus86
1997 - 2003 F150
Jun 13, 2013 06:14 AM
Jack-o
Jun 10, 2011 06:10 AM
Dave85zxt
Jan 7, 2004 04:16 PM
