Clutch bolts
Old Aug 9, 2011 | 08:02 PM
elnino's Avatar
elnino
Clutch bolts
I need the bolts that put the clutch to the flywheel, i ordered some from summit for a mustang, and they are to small, I called the dealer and they told me they were different parts numbers..but I cant find them anywhere! Help!!
Thanks in advance
Old Aug 9, 2011 | 08:13 PM
Shark Racer's Avatar
Shark Racer
They're called pressure plate bolts - what engine and transmission are you working with?
Old Aug 9, 2011 | 08:22 PM
ctubutis's Avatar
ctubutis
What part numbers did the dealer give you?
Old Aug 9, 2011 | 09:00 PM
elnino's Avatar
elnino
I left them at work, is a 302 but the flywheel,pressure plate and clutch are from an 88 f150 I got them my self from the parts store
Old Aug 9, 2011 | 09:04 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Edit Sorry wrong answer.
That part number is for the flywheel bolts to crankshaft flange.
Let me try to find it on my CD... BRB, I hope
They are called "place bolts"
The head is undercut and acts like a Bellville spring to keep the tension even under shock loads.
They're same for almost all ford V8's
Try F1ZZ*6379*A for 6 pieces.
Old Aug 9, 2011 | 09:48 PM
elnino's Avatar
elnino
the part number you gave me is for the flywheel to crank...i need the pressure plate to flywheel....
Old Aug 9, 2011 | 09:50 PM
elnino's Avatar
elnino
i mean if i cant find the part number i will just use some grade 8 bolts with a locking washers but i was wondering if the only idiot running into this problem...
Old Aug 9, 2011 | 11:44 PM
ctubutis's Avatar
ctubutis
Call up Green Sales Company - 800-543-495 - (they have 83 of them) and give them this part number:
355705-S BOLT - PRESSURE TO FLYWHEEL - 3/8-16 X 31/32
Fits 1980/89 (the only years this catalog covers) F100/350 V8 302 & 351
Section 71 Pg 15
Also takes a lockwasher 34807-S but I don't think they (or anybody else) have those, I'd go to a hardware store.
Old Aug 10, 2011 | 12:23 AM
elnino's Avatar
elnino
i will give them a call tomorrow thanks a lot, but question..can i use just use some grade 8 bolts from a hardware store?....j
Old Aug 10, 2011 | 12:36 AM
ctubutis's Avatar
ctubutis
I wouldn't.
They're basically Shoulder Bolts and look something like this:
I lost one once during a clutch replacement job, I think it fell in a crack in the concrete. Ford dealers weren't any help, got some from a local machine shop or some such.
Old Aug 10, 2011 | 05:06 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Yes, I understand that.
I knew the flywheel bolt number by heart but needed to look at the Hi-Po parts CD for the right number for the early shouldered bolts.
Both my phone (which I posted from) and my netbook don't have an optical drive.
So... I needed to clear off and fire up the old desktop PC.
Then IT didn't want to stay connected to my wireless router.
Chris got you the number. Thanks Chris!
On my 347 stroker smallblock we used ARP 250-2201 12 point bolts.
They weren't expensive IIRC but I don't know if you have a performance store near you.
Sorry to hijack your thread.
Old Aug 10, 2011 | 07:56 AM
elnino's Avatar
elnino
thanks a lot for all the help!! im glad im a ford guy ...
btw i only need 6 bolts right?
Old Aug 10, 2011 | 09:13 AM
ctubutis's Avatar
ctubutis
Yes, 6 + washers.
oharal
Mar 7, 2019 06:14 PM
bmxerbrett
Mar 21, 2016 11:35 AM
Oakroadjoe
Feb 26, 2015 10:38 PM
mtfleming11
Nov 25, 2012 01:00 PM
84-250
Mar 23, 2008 04:17 PM
