Break-out box question
Old Aug 9, 2011 | 11:53 AM
Tim Young's Avatar
Tim Young
Active Streak: 30 Days
I'm in need of a Break-out box to isolate an intermittent miss. I'm wondering if anyone has an idea for an inexpensive alternative to the expensive commercial units?
I am looking for something I can isolate one injector at a time with.
I am thinking about building a break-out box to plug in right at the valve covers and then have 8 switches mounted in a box that I could isolate each injector one at a time. Do you think that would be possible?
Old Aug 9, 2011 | 12:54 PM
DIYMechanic's Avatar
DIYMechanic
The difficult thing is going to be pinpointing your issue, since it only happens while you are driving the truck. If it were missing all the time this could easily be accomplished by pulling the VC's and unplugging the injectors one at a time. You can also look at the poppets to see which one isn't spurting oil to determine which injector is missing, but there again, it has to be missing all the time in order for you to pinpoint the issue.
What about running a buzz test? That may help you identify an injector with a weak solenoid. Jim is going to be the expert on this one, so I would ask him whether this would help as opposed to using a break out box. The thing is, even with a break out box, it is going to be really tough to isolate this weak injector since it only misses intermittently. Unless, that is, you can make it do it consistently. Then I can see where a break out box might be of some value.
Old Aug 9, 2011 | 01:36 PM
wmiller's Avatar
wmiller
I love my aeroforce gauge. Can pull codes, run contribution test and buzz test plus monitor multiple parameters
Old Aug 9, 2011 | 01:37 PM
wmiller's Avatar
wmiller
http://www.aeroforcetech.com/products_interceptor.html
Old Aug 9, 2011 | 02:23 PM
fordpride's Avatar
fordpride
Just a shot in the dark but I had what I thought was a miss will driving and it turned out to be the TPS cutting out it had a bad spot in it
Old Aug 9, 2011 | 03:17 PM
IDMooseMan's Avatar
IDMooseMan
Mike, how did you determine the TPS was bad?
Wmiller, thanks for that link. I'm gonna check it out.
Old Aug 9, 2011 | 03:25 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
I have some Aeroforces Gauges in stock.
Though I don't see how that would help Tim.
I suggested that Tim make or borrow a break-out box.
He seems to be able to replicate the miss, and I really think shutting the injectors off one at a time while it's missing will help narrow down his issues.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Aug 9, 2011 | 03:35 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Is your problem similiar to this?
‪1995 73L Powerstroke‬‏ - YouTube
He ended up replacing the IPR and it fixed it. Some people commented that have similiar problems, might find a solution.
Old Aug 9, 2011 | 03:42 PM
fordpride's Avatar
fordpride
With CC on it wouldn't miss
Old Aug 9, 2011 | 04:13 PM
IDMooseMan's Avatar
IDMooseMan
Apologies to the OP for the
My CC will shut itself off for no apparent reason. I've had the CC recall procedure completed, but still have the problem of CC shutoff by itself.
Is the TPS replacable or do I have to buy an entire pedal assembly to get it?
Old Aug 9, 2011 | 05:51 PM
fordpride's Avatar
fordpride
Craig PM sent
Old Aug 9, 2011 | 06:04 PM
superduty4x4's Avatar
superduty4x4
There was a thread in the SD forum with details on how to do exactly this... stand by.
Old Aug 9, 2011 | 06:08 PM
superduty4x4
https://www.ford-trucks.com/forums/6...with-pics.html
Old Aug 9, 2011 | 06:30 PM
tjbeggs's Avatar
tjbeggs
I have some PDF files that detail making one that hooks into the large connector just over the drivers side valve cover. Its pretty involved by getting the correct connectors at a salvage yard. There are many fords that use that same large connector so that is not very difficult. Let me know if you want them.
Old Aug 10, 2011 | 12:26 AM
Tim Young's Avatar
Tim Young
Thanks guys,
Tim, I sent you a PM
Chase, Thanks for the link, nice write up but I couldn't get the pdf links to work. P.S. I am headed up to Cub lake on the dirt bike this coming weekend.
Ford4Life7.3, No it doesn't sound like that.
Craig, No problem on the Hi-Jack. I'll check it out, it can't hurt to try.
