Offroad & 4x4
D44 Clunking
Old Aug 9, 2011 | 07:44 AM
roosplash's Avatar
roosplash
D44 Clunking
Been experiencing the front axle clunking when coming to stop. In an effort to diagnose what is causing the problem can I remove the front Auto hubs temporarily and drive it to make sure those arent whats causing the clunking?
Old Aug 9, 2011 | 07:54 AM
alpha/omega's Avatar
alpha/omega
Id take a look at the wheel bearings and u-joints first but yes you can drive with the auto hubs removed.
Old Aug 9, 2011 | 09:40 AM
roosplash's Avatar
roosplash
Thank you. Just trying to eliminate the issue one part at a time from the outside in
Old Aug 9, 2011 | 09:48 AM
joe f350's Avatar
joe f350
if it is a ttb i would check the jont in the middel in of the axle
Old Aug 9, 2011 | 12:51 PM
captain p4's Avatar
captain p4
What year is the truck?
Check all the bushings on the axle/radius arms.
Old Aug 9, 2011 | 06:14 PM
roosplash's Avatar
roosplash
89 Bronco with auto hubs. All the noise is coming from the front drivers side when the truck comes to a stop. But it doesnt happen every stop. Sounds like a clunk noise. I removed both front hubs to try to narrow down the problem. I figure hubs, bearings, u joints or sticking caliper
Old Aug 9, 2011 | 10:17 PM
roosplash's Avatar
roosplash
Well Ive driven it all day without the hubs and it hasnt acted up at all. Ill run to the junk yard tomorrow and find a set of manual hubs to replace them. Should manual hubs from any D44 axle work regardless of make? Is there something I should know about switching from auto hubs to manual hubs that Im not aware of?
Old Aug 10, 2011 | 07:49 AM
tjc transport's Avatar
tjc transport
i ain't rite
i am not sure, but i seem to remember reading about having to use an adapter kit to convert from auto to manual hubs.
Old Aug 10, 2011 | 08:13 AM
alpha/omega
on some models not all.
Dave helped Joe swap his over. Maybe he will chime in on the specifics. I cant keep track of it all...especially since I dont do it on a regular basis.
Old Aug 10, 2011 | 08:28 AM
hav24wheel's Avatar
hav24wheel
5 bolt auto hubs can be swapped over for manuals off almost any ford,chevy D44 for sure. Just make sure to pull the inner "c" clip and spacer off the outer shaft after you pull the autos off.
Old Aug 10, 2011 | 10:07 AM
joe f350's Avatar
joe f350
yea the swap is easy all u have to do is pull hubs and u should have a problems and the c clip on the axle
Old Aug 10, 2011 | 11:37 AM
roosplash's Avatar
roosplash
Well no luck at the junk yard for a set of hubs other than one yard wanting $50 a piece for a set, heck I can get new ones for $60 a piece so I passed. Ill just tear down the auto hubs i have and try to rebuild them if thats possible
Old Aug 10, 2011 | 12:32 PM
kjett's Avatar
kjett
Why not just ditch the autos that are prone to breakage and get you a set of Warn hubs and call it done? Yeah, you'll have to get out and lock them in manually, but you won't have to worry about the lock-unlock-relock deal they do when changing direction or putting too much of a torque load to them.
Old Aug 10, 2011 | 02:04 PM
captain p4's Avatar
captain p4
He said he was looking for a set ********...
Old Aug 10, 2011 | 02:34 PM
tjc transport
i ain't rite
be nice Paul.
it ain't Karls fault he cant read.
