won't start after rebuild
Old 11-30-2002, 12:29 PM
Ford Truck Racer's Avatar
Ford Truck Racer
Ford Truck Racer is offline
rebuilt my motor, got it in and it won't start, turns over and has fuel. Any suggestions or comments. As far as I can tell the distibutor is 8-10 btc and all wires are hooked up.
Old 11-30-2002, 12:32 PM
slave2dafords's Avatar
slave2dafords
slave2dafords is offline
is it trying at all or is it just cranking and cranking. did you do a transplant or is it the same engine just refreshed?
Old 11-30-2002, 07:07 PM
CrazyFordMan's Avatar
CrazyFordMan
CrazyFordMan is offline
You might be 180 degrees off in the timing my budy did the same thing with his sb chevy it would crank and crank but no fire
1992 F250 r/c l/b 4X4 351 ZF5spd 33" BFG Allterrains
Old 11-30-2002, 10:27 PM
Ford Truck Racer
Figured it out. thanks for your help. I was off 180. But now have another problem. It starts and has oil pressure then as it runs loses it. For a fresh rebuilt it is smoking real bad, worse than would of thought for unset rings. I know it will till it breaks in. Any suggestions as to why it loses oil pressure. I pretty sure I hooked oil pump up right.
Old 11-30-2002, 11:21 PM
slave2dafords
well i hope to god that it is only the sensor acting funny otherwise your engine wont break-in it will break. i have not had one smoke real bad out the pipes not even the one that only went 5.1 miles before seizing (lol no i did not do the rebuild) did you prime the oil pump before you started it and did you do the cam break in?? 20 minutes @ 2000rpm
Old 12-01-2002, 06:40 PM
gamehunter's Avatar
gamehunter
gamehunter is offline
If you are using a roller cam dont worry about this...If you were cranking and It didn't start that could be bad. Flat tappet cams need to be started and taken to 2000 rpm immediately upon startup to circulate oil around the camshaft for lubrication. I don't know how critical this is or what kink of damages could result from it though. You did use a new oil pump right?
Old 12-01-2002, 08:54 PM
Redneckerson's Avatar
Redneckerson
Redneckerson is offline
Elizabeth Mcnabb
12-14-2015 08:38 AM
Johnjohnjohn3
Modular V8 (4.6L, 5.4L)
03-19-2015 06:27 PM
ss27gogeta
02-20-2015 09:16 PM
hunter444
13
04-30-2014 09:32 AM
Quick Reply: won't start after rebuild
