4.9 fuel injection help!!
Old Aug 8, 2011 | 04:03 PM
wilddog's Avatar
wilddog
I need some help on what to do. My '91 F-150, 300 in. six was hesitating when I gave it gas at low speed and was hard to start when warm. I replaced O2 sensor and spark plugs- no change. Shop said injectors were leaking down and cleaned them with the stuff they put in the rail. It didn't help so I put in new injectors myself and it runs much better but is still hard to start warm. I need to put the pedal on the floor and crank a lot then it acts rich until cleared out. Starts good cold. I thought it might be the pressure regulator and put a gauge on the rail. It reads as it should, key on 58#, idle 48#, vac line pulled and it increases about 10#. It doesn't leak down when engine is stopped so I guess the injectors are ok now. Reads almost the same hot or cold. Any ideas what to do next?
Old Aug 9, 2011 | 03:22 PM
wilddog's Avatar
wilddog
Fixed! I looked back over past post and decided to try replacing the ECT and ACT sensors even though shop said code reader showed no problem with any sensors. That did the trick, runs great now with new injectors, plugs, O2, ECT and ACT sensors. Ready to go another 20 years!
wesweav
Sep 5, 2016 04:25 PM
tcwilson
Aug 25, 2014 02:40 PM
Don222
32
Sep 3, 2007 07:26 AM
96EddieBauer
Bronco II
Mar 30, 2006 09:23 PM
dan13
Oct 2, 2005 06:49 PM
