New Injectors causing rich condition
Old Aug 25, 2014 | 01:06 PM
tcwilson's Avatar
tcwilson
I installed new fuel injectors in my 2003 Expy with 5.4L engine.
Started up and ran great, but then threw codes p2196 and p2198 which are oxygen sensors biased/stuck in Rich condition. Using data logging on my code reader, the O2 sensors were pegged at 1V and never moved off of that. And long term fuel trim remained at 0 throughout the ordeal.
When I put my old injectors back in, i started getting the normal readings for my O2 sensors and normal reading for fuel trim.
Anyone have a guess as to why a brand new set of injectors would cause a rich condition that the PCM couldn't correct?
thx for any and all replies.
Old Aug 25, 2014 | 01:38 PM
David7.3's Avatar
David7.3
How old are the o2's The o2's can be fixed rich with the new injectors cause the lean condition for so long damaged them! with your new injectors did you reset fuel adaption? How about force a vacuum leak and see if the o2's respond? I would do a complete fuel relearn, fuel pressure regulator working properly?
Old Aug 25, 2014 | 02:03 PM
alloro's Avatar
alloro
Were the injectors an exact replacement? You can get injectors to fit but have a different flow rating. It's always best to get the number off an original injector and order new based on that number rather than by application.
Old Aug 25, 2014 | 02:37 PM
tcwilson's Avatar
tcwilson
The O2 sensors are only 2-3 years old.
I reset the fuel adaptation the only way I know: disconnect the battery for 15-20 mins.
I tried unplugging a vacuum hose and did see the O2 sensor respond with lower voltage.
Fuel pressure is running 52 psi key on, engine off, and 58 psi engine running.
I haven't tested the fuel pressue regulator yet.
Old Aug 25, 2014 | 02:40 PM
tcwilson's Avatar
tcwilson
I thought the injectors were exact replacements. But I haven't cross referenced the part numbers yet. I will do that. I had a suspicion that maybe the new ones were rated for a higher flow rate, but haven't been able to find flow specs for injectors to this point.
bublaw
Feb 14, 2014 04:36 PM
jemini
Sep 17, 2012 11:19 AM
robbyk85
1997 - 2003 F150
Mar 5, 2011 01:42 AM
DeenHylton
Apr 6, 2002 09:53 PM
otto
Apr 5, 2001 03:51 PM
