Sponsored by: Auxito
Towing with SuperCrew
Old Aug 8, 2011 | 12:03 PM
joe krawczak's Avatar
joe krawczak
I have a 2001 SuperCrew with a 5.4 motor & 3.55 limited slip diff. I pull a 7500 pound TT and only can get 8 mpg tops. The truck seems to run fine with decent power. I keep max air pressure in all eight tires, use mobile 1 5w-20, has a new air filter and all fluids have been updated. I try not to exceed 60 mph while towing and always keep the overdrive off. Seems to me I should get better mileage, am I dreaming or does the truck have issues?
Old Aug 8, 2011 | 12:33 PM
Bluegrass 7's Avatar
Bluegrass 7
It's normal.
Looking at the towing specs for an 01 SCREW, your GCWR is 13,000 lbs max.
If the truck weighs 6750 loaded to it's max, 13000-6750= 6250 as max trailer weight.
7500-6250=1250 over the limit +/-.
As it is now, if the truck weighs even 6500 +7500 trailer = 14,000 total gross combined weight.
If your running the truck at less weight for passengers and misc weight then you come closer the the legal mac GRCW.
Your mileage would be expected.
Good luck.
Old Aug 8, 2011 | 02:34 PM
joe krawczak
Appreciate the response. I was looking at max trailer weight and GVWR to determine if I was overweight. Forgot all about the combined weight limit (GTWR), which appears to be the limiting factor. May be time for a new truck.
Old Aug 8, 2011 | 02:48 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
I towed a 7500lb race trailer for a few years with my 99 Ford. At 70+ mph the truck would get 7-8mpg. If i slowed to 55mph i was able to hit 9-10.
The trailer is heavy no matter how you slice it. The only way your going to get any better MPG is with a 2009 or newer ford with the 6 spd.
Or you could get a a F250 with a diesel. It might net you a few Mpg.
Truth of it is, when towing something that heave, MPG are going to go down, especially with higher speeds.
Old Aug 8, 2011 | 10:30 PM
dilas's Avatar
dilas
Unfortuately, it's about right. I have a hybrid trailer at about 5-6K. Towing loaded around the mountain, it's about 8-10 mpg average. If I get over 10-11, I get excited. Gee! My worst was 6-7 mpg driving against the wind up and down slopes. I drive conservately, and try to keep the RPM at minimum around 3K to 4K. Try not to go over if possible.
Old Aug 8, 2011 | 10:54 PM
Bluegrass 7
When towing at or over the weight limits, expect anything to happen.
If you 'grunt' the motor wide open on a steep a hill in low gear at low speed, the converter becomes under huge pressure from engine torque against the total weight.
This can 'balloon' the converter and your in for a trans rebuild if the bearings breakup and go through the transmission and get into the radiator cooler and aux cooler.
A good shop will either replace them or back-flush with a hot solution to be sure they are clear, unblocked and don't give up debre back to the new transmission and wreck it again..
I had this happen with a 4.6L and decided not to rebuild back to stock and have it happen again so a custom built HD was done by Level 10 at big bucks but did the job.
That trans is still going today and is the reason I have not given up the truck for a new/other truck..
These are things to know and hear that is hard to come by unless these kinds of discussions come up.
Good luck.
milkweed.gardener
Feb 17, 2017 09:38 AM
strato1
2009 - 2014 F150
21
Feb 3, 2010 10:02 PM
jp_foster
1997 - 2003 F150
Nov 3, 2008 09:48 AM
HSTC
All Things Towing
Apr 17, 2008 11:22 AM
2003150
All Things Towing
Sep 28, 2004 01:26 PM
