Need to do U-joints
Old Aug 8, 2011 | 11:55 AM
UncleShank's Avatar
UncleShank
Need to do U-joints
Is there any write-ups about doing it to the front end? I searched the forums and it didn't give me any answers. Also I need my driveshaft rebuilt. Is that something I could do at the same time to save time and money so the dealership can get money from someone else? I'm not to mechanically inclined, but I will be going to a local tech school to be a diesel mechanic and want to start with my truck so I can know some before I go in. Any help would be appreciated
Old Aug 9, 2011 | 12:05 PM
Brother Les's Avatar
Brother Les
bump......
Old Aug 9, 2011 | 12:45 PM
nlemerise's Avatar
nlemerise
You might want to consider this option...drop the driveshaft(s) and take to a local driveline shop. They will press the u-joints out and press in new ones for you. Then all you have to do is reinstall them. Most driveline shops will let you watch if you ask...
When I pull driveshafts I always mark both ends and the connection points (say transfer case yoke and differential yoke so I can put it back in exactly the same position as it was). Probably overkill, but so easy as to be dimwit proof.
This isn't to say you can't press out the u-joints and press in new ones, but I just thought I would offer the alternative (half way between having the dealer do it and you doing the whole thing yourself).
Old Aug 9, 2011 | 01:03 PM
UncleShank's Avatar
UncleShank
Thank you. I will try to find one around me. Would it be like a transmission shop or something else?
74FEMotorMan
15
Jan 16, 2012 08:29 PM
SHOpar
Jun 21, 2009 10:32 AM
40LUTZAG
1997 - 2003 F150
Apr 25, 2008 07:33 PM
samsno1
N. California Chapter
Mar 8, 2008 08:43 PM
lallen
Mar 30, 2001 02:44 PM
