2011 FX4 Squating
Old Aug 12, 2011 | 11:40 AM
Hd05's Avatar
Hd05
I have the F350 dually I tow 18k 5th wheel with pin weight of 4050 lbs. Truck squats 1 7/8
inches. Haven't added bags yet. I also get a noticeable launch vibration from 5-12 mph.
Old Dec 30, 2011 | 06:17 PM
blueline38's Avatar
blueline38
rear sag
Just installed (had installed) the readylift 4" blocks. The truck looks like a truck and can squat a couple of inches without causing a reverse rake!
before
after
Old Dec 31, 2011 | 06:43 AM
glsurratt's Avatar
glsurratt
If you have enough of a load to get down on the overload springs, keep an eye on the rubber bump stops that hang down on the brackets at the rear of the springs. I tore up my first set at 10K miles, second set at 11K and third set at another 500 miles. Rather than stop at a dealer for replacements every 1000 miles, I bit the bullet and put Firestone Ride-Rites with an Air Station and automatic leveling valve on my F-450. My kingpin weight is 4,000 lbs. and the truck was squattin about 2 inches without the bags.
Old Jan 1, 2012 | 06:27 AM
rkmfordman's Avatar
rkmfordman
Originally Posted by basskicker
Just wondering, why does my new FX4 squat so easy with minimal load. Are the shocks to soft, does that have anything to do with it. Or is it all springs. Ican put a 12 foot utility trailer on the back empty and she will drop 1 inch.
ive had good luck with supersprings had em on my 07 and now on my 11 quick and easy to install and maintain factory ride when unloaded and they are adjustable.
Robert6401
Jul 25, 2020 04:49 AM
pilgrimbizket
6.7L Power Stroke Diesel
13
Apr 9, 2019 05:00 PM
Turpentine
Jun 28, 2018 08:06 AM
the_auto_tech
2009 - 2014 F150
20
Apr 3, 2017 01:00 PM
mtyrell
May 9, 2003 09:33 AM
