RAS still suggested??
Old Nov 6, 2017 | 08:54 AM
Robert6401's Avatar
Robert6401
Hey guys, just curious if the RAS is still a well thought of system for beefing up the rear end of these beasts. I tried a set a few years back on my truck, but ended up going with an airbag setup instead. However, I really liked the way the RAS improved the ride of the truck. I think it would be the perfect solution for my Ex's aging springs. The Ex actually has airlift airbags on it now, installed by previous owner, but they don't really give me the ride I'm looking for. Plus they're leaking, so they probably need to be replaced anyways.
Thanks for the help!
Old Nov 6, 2017 | 09:25 AM
pirate4x4_camo's Avatar
pirate4x4_camo
No, never "well thought of" they are an expensive add a leaf that adds spring rate which is not needed.
If your leaf springs have sagged you need new leaf springs that have the correct arch for the ride height you desire.
To determine if your leafs have sagged or how much they have sagged measure from the center of your wheel hub to the bottom of the fender arch at all 4 corners.
Stock new should be:
Front 23
Rear 24
Important to remember that ride quality is determined by your shocks not the springs. That said it is likely your right front leaf is sagged the most and has blown off the bump stop and your shocks are shoot.
Old Nov 6, 2017 | 10:15 AM
Robert6401's Avatar
Robert6401
Front 23
Rear 24
Thanks, the truck is a 2WD, so no front leafs. You actually helped me before and we collectively decided I should try shocks before doing anything as my measurements don't necessarily show significant sag. I did that, and the new shocks helped SOME, but the rear still bottoms out when I hit a bump, sending the kids in the backseat into a frenzy as they get slammed. I HAVE to do something about the rear bottoming out. My brief experience with the RAS was good, and I thought they were a popular upgrade around here, but I could be mistaken. I'm almost to the point of doing the 6" lift, just to get this thing to ride better. As it is, we use it because we have to for our large family, but we dread it.
Old Nov 6, 2017 | 10:18 AM
JIMBO_FID's Avatar
JIMBO_FID
I had a new main leaf and a mid pack leaf added and my Ex barely squats when I put my trailer on and it has a 1300lb ball weight. I do have air bags still but there is only 20lbs in them so they really aren't doing much now.
Old Nov 6, 2017 | 10:45 AM
pirate4x4_camo
2wd should be
Front 21"
Rear 22"
Before you go adding aftermarket bandaids to cure your problem figure out what the problem actually is.
In proper working order your Ex should not be bottoming out during normal driving on moderate roads, if you are jumping it or hoping curbs then sure.
Old Nov 6, 2017 | 10:48 AM
pirate4x4_camo
Which shocks did you install ?
Old Nov 6, 2017 | 01:47 PM
Robert6401's Avatar
Robert6401
Oh no, not jumping or hopping curbs, just anything other than a slow crawl over railroad tracks, potholes, etc. Normal driving. I agree that there is a problem. The measurements don't show one, but I know it shouldn't ride that poorly. I believe I installed some Monroe shocks, but I honestly can't remember which ones. Whichever they were, I remember when researching it about 6 months ago, they were fairly well recommended. Besides anything should've been an improvement over the stocks that were still on there.
Old Nov 6, 2017 | 03:31 PM
pirate4x4_camo
When you get a chance crawl under and get a picture of each side leaf spring.
Check your air bag mount setup. Just a thought but perhaps the mounts are wonky and limiting travel.
When you measure remember to let all the air out of your air bags.
Old Nov 6, 2017 | 03:50 PM
Stewart_H's Avatar
Stewart_H
You are not mistaken, is was not uncommon for a lot of the guys that tow, to add the RAS.
While I am of the same mindset as Camo (fix the problem, don't use a band-aid), the RAS will do what you're hoping.
I've had an RAS sitting in my garage for over 10 years, and just put it on earlier this year and it works well for what it was designed to do, assist the rear suspension in handling weight.
Stewart
Old Nov 6, 2017 | 04:22 PM
Robert6401's Avatar
Robert6401
I'll try and get some pics. Will probably be tomorrow at this point. Thanks!
Old Nov 6, 2017 | 08:39 PM
catman1's Avatar
catman1
If your ever up in the Raleigh, NC area let me know...I have a set I would give to you for free, even install them for you! They came off of a 2001 F250 I used to have, held on to them since, I have no need for them and would like them gone.
Old Nov 7, 2017 | 06:13 AM
ghmason's Avatar
ghmason
RAS doesn't change the "stance" of the Ex (the measurements Pirate referred to) just beefs the rear for when the trailer is attached - correct?
Old Nov 7, 2017 | 06:45 AM
Robert6401's Avatar
Robert6401
Wow, what an offer! I don't see making it up to Raleigh anytime in the foreseeable future, but would you be willing to send them to me if I cover the shipping?
Thanks!
Old Nov 7, 2017 | 06:47 AM
Robert6401's Avatar
Robert6401
The RAS will raise the rear a bit.
Old Nov 7, 2017 | 09:12 PM
Stewart_H's Avatar
Stewart_H
Nope, it raises the rear a bit, like Robert posted above.
Stewart
