Please help....
Old Aug 11, 2011 | 08:27 AM
Bryan da Preacherman's Avatar
Please help....
1999 Ford Eddie Bauer Exp.
Here is the deal. I was driving down the highway about three weeks ago... lights started diming and the radio when out. I made it to an AutoZone where they checked the battery and the Alternator. I was told that battery was dead, and that it needed to be replaced. The battery was from '04 so I did not get too concerned.
Fast foward three days, and the SUV runs fine, until I stop to fuel it up, and this when I turn the key, its dead. Get a jump and head back to AutoZone. They test it again, and tell me the alternator is going out. So I buy a new alternator and put it in.
As I am taking the old one back for the core charge, the battery light comes on. It had never come on before but it was on now. They tested it again, and I was told that it was fine the "ERU" needed to sync up and that it should be good in a day or two.
Since that time, the battery light has come on and off serveral times and just yesterday that battery died completely.
I tested the Voltage while running and got 14.2 at the battery, the leads to the alternator, and the inline fuse... I am stumped...
Old Aug 11, 2011 | 09:32 AM
Alcaeus's Avatar
Alcaeus
Do you have draw on your battery when the truck is off?
Old Aug 11, 2011 | 09:41 AM
kailor's Avatar
kailor
If you purchased a remanufactured alternator then I would say that is the culprit. I had my mechanic replace my alternator yesterday. My light had been coming on. I replaced the old alternator with a 100% NEW Ultima from O'Reilly's. How good this alternator will turn out to be remains to be seen.
Do over...
if you are getting 14.2 with car running then the system is charging as it should. Check for something draining the battery as Alcaeus suggests or loose belt.
Old Aug 11, 2011 | 10:38 AM
Well I tested the Voltage before when the light came on the first time. I have not gotten the same result now. Obviously the alternator is not keeping the battery charged.
Alcaeus... I do not have any draw that I am aware of. There are no accessories or chargers plugged, unless there is something built into the car that I am unaware of.
The Ford dealer did say that the after market alternators did not play well with the Expeditions, and yes it was remanufactured.
Old Aug 11, 2011 | 12:11 PM
alloro's Avatar
alloro
You said the battery needed to be replaced, but you never did say if you replaced it.
Old Aug 11, 2011 | 12:20 PM
Yes sir, replaced it on that Monday and then the alternator two days later on Wednesday night
Old Aug 11, 2011 | 05:20 PM
alloro's Avatar
alloro
How about belt slippage?
Does your belt tensioner seem to be applying reasonable pressure to the belt?
Is the belt in good condition?
Old Aug 11, 2011 | 05:25 PM
It appears to be tight and in good shape
Old Aug 11, 2011 | 05:29 PM
alloro's Avatar
alloro
Then you have a bum alternator. This is why I don't get remanufactured parts if at all possible. Often, the rebuilders don't rebuild them completely.
Old Aug 11, 2011 | 05:33 PM
Could that possibly allow the alternator to work intermittently for a time or two
Old Aug 11, 2011 | 08:01 PM
ronjeremy6's Avatar
ronjeremy6
+1 on the alternator. My 99 did the same thing, windows wouldn't even roll down.
Old Aug 11, 2011 | 09:41 PM
alloro's Avatar
alloro
Yes, especially if the slip rings or brushes are worn or dirty.
Old Aug 12, 2011 | 01:29 PM
Well guys... thanks... it appears it was a faulty alternator... so we replaced it and are back in business... also replaced the battery...
johnarla
Mar 28, 2013 11:18 AM
stevorino
Apr 25, 2012 06:45 AM
mandrielle
Sep 3, 2007 04:14 PM
john1
Aug 22, 2006 12:46 PM
VIKING24
Feb 17, 2006 10:12 AM
