Rough idle/ hard start and backfired
Old Aug 7, 2011 | 03:41 PM
bad12jr's Avatar
bad12jr
Ok guys after getting this thing back together. It has a hard start hot issue and a rough idle all the time. It has no bottom end power hardly at all.
The thing almost sounds like a gasser running. Last night ran the mud sling at the fair and I had to pull around the pits in first because it wont hardly take off in second.
Last night after driving around town I took off and went from second to third on it pretty good and it back fired. Im going to check the uvch and push rods. Could the hpop and or the ipr be causing the problem.
I put the ad's and 17 * out of the sd motor I got.
Old Aug 7, 2011 | 04:28 PM
rodneywar's Avatar
rodneywar
are u running a chip tuned to accmodate the ad split shots if not thats your problem our trucks were programmed to use single shot injectors
Old Aug 7, 2011 | 04:34 PM
bad12jr's Avatar
bad12jr
Yea its tuned for it. Sorry I forgot my sig didn't post. It should this time
Old Aug 7, 2011 | 08:10 PM
tjbeggs's Avatar
tjbeggs
AD's wouldn't be the issue even it still ran single shot programming. Is this the engine you just rebuilt?
I would be looking into if you have the valve timing correct or is you have a rocker arm issue.
Old Aug 7, 2011 | 08:41 PM
bad12jr's Avatar
bad12jr
I replaced the front cover. It started at idle and the no power all of a sudden. I pulled the idm out and apart it looks good and clean. It doesn't smell burnt. I have ipr o rings on order but stuck my ipr from the 15* in and it didn't help but it worked good before. Im gonna pull the valve covers this week.
At first I thought it was just the ipr or weak hpop. The backfire is what threw me for the loop.
Old Aug 7, 2011 | 08:45 PM
tjbeggs's Avatar
tjbeggs
Ok Good. Front cover definitely not a timing issue. I though you rebuilt it. Must have been someone else.
I would guess UVC or IDM but hard to tell. Any CEL on?
Old Aug 7, 2011 | 09:14 PM
bad12jr's Avatar
bad12jr
Will throw a Cel on a long hard pull. But I think its from the hpop. It only does it in the higher tunes. I need a scan gauge or ae. Would help alot but gotta pay for some other things
afrees
6.4L Power Stroke Diesel
Sep 5, 2014 03:12 PM
miller_feed
28
Dec 10, 2008 08:46 PM
Bin Strokin
23
Aug 22, 2008 10:36 PM
Beechnut
Aug 31, 2004 07:47 PM
