F250 steps bars
Old Aug 7, 2011 | 02:29 PM
labman1014's Avatar
labman1014
F250 steps bars
I know this is on here somewhere but all I have now is my iPhone and searching can be a pain. There r a few f250 chrome step bars in the local craigslist forsale. Will these bolt right up to the Excursion?? Do I need to look for crew cab only? My oem running broads r in ok shape but one bracket on the drivers side is about rusted off. I was thinking about updating the look a lil. Tks in advance.
Old Aug 7, 2011 | 02:57 PM
BigPigDaddy's Avatar
BigPigDaddy
I am pretty sure the crew cab Super Duty step bars will fit because I put a set of factory X running boards on my crew cab Super Duty.
Old Aug 7, 2011 | 05:54 PM
wpnaes's Avatar
wpnaes
Measure first, as I recall the SD step bars are 6 inches shorter than the Ex's. If you're **** about these things, you won't be happy. The mounting brackets underneath will be fine. Did the brackets rust off (they're pretty thick) or did the stamped steel 'board' under the plastic top rust away? The reason I ask is because I have extra brackets if you need one.
Old Aug 7, 2011 | 07:47 PM
labman1014's Avatar
labman1014
It's what's under the plastic. Not the bracket. My bad.
Old Aug 7, 2011 | 10:05 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
99'-12' crew cab running boards are identical if your speaking factory anyhow.
i had a set of '03 chrome tube bars off a f-250 on my '04 excursion..bolted right up.
Old Aug 8, 2011 | 03:17 PM
labman1014's Avatar
labman1014
What would u say is a good price for a set??
Llaslo
Ford Truck Parts for Sale
Apr 27, 2015 04:50 PM
kd4gij
1997 - 2003 F150
Oct 12, 2014 08:15 AM
PsRumors
Nov 29, 2010 11:20 AM
avia
Feb 25, 2010 05:51 AM
