390 Backfire
Old Aug 6, 2011 | 09:19 PM
Green 73's Avatar
Green 73
390 Backfire
I have a 73 F100 with a 390. Truck has sat for a while but I just rebuilt the carb, replaced fuel pump and filter and coolant system. The truck will run strong but then out of no where will let out a huge backfire out the tailpipe and stop running. After pumping the accelerator a bunch it will fire up but it might be 10 miles or 50 and it will do the same thing again. Seems to be most active while under a load. Any Ideas?
Old Aug 6, 2011 | 10:22 PM
co425's Avatar
co425
Carb settings or timing. With the description I would lean torwards timing.
Old Aug 6, 2011 | 10:32 PM
Green 73's Avatar
Green 73
Thanks for the reply. When I initially got it running after it had sat for a year, I set the timiing at 6. Is there a better setting?
Old Aug 6, 2011 | 10:52 PM
co425's Avatar
co425
Set it at 12 to 14. Warm her up drive her around a bit and push on the gas hard if she doesn't ping you should be good to go.
jlaudio_f100
55
Mar 26, 2011 05:58 PM
MrMadhead
May 15, 2009 08:49 AM
brad76f250
Jul 26, 2004 10:20 AM
1968 F250camper
Apr 19, 2004 12:59 PM
ktownford
Dec 24, 2003 09:03 PM
