Hot air coming when AC is on
Old Aug 11, 2011 | 03:16 PM
mhancock2's Avatar
mhancock2
Would a new blower be better than the factory? You are right they are slow and they suck. I want snow in my cab dang it. I know it is cold air, put your hand next to the vent and it is ice cold, but it is like it doesn't have the umph.
Old Aug 11, 2011 | 05:42 PM
damac's Avatar
damac
I tried one and can't say so. And they do seem to have like half the airflow over a newer full sized truck from what I have seen. Maybe part of that would help the perception of how cold it gets as well. I don't know what its like for people in the back seat on those hot days.
But there is a mod some have done in wiring a full voltage kind of turbo speed hooked to a push button for the ac. I have it saved to my desktop but have not tried it yet.
Old Aug 11, 2011 | 06:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
i don't know about that.
my 88 is like a meat locker inside. it can be 100 degrees outside, and it will be in the 50's inside.
and that truck has close to 500,000 miles on it.
Old Aug 23, 2011 | 08:00 PM
mhancock2's Avatar
mhancock2
Ok guys I am still having problems with it. The air comes out and it is cool, but not cold. I have checked everything. I have checked and I have regrigerant, what else could it be? I noticed the A/C Accumulator is freaking ice cold, much colder than the air coming out of it. Not sure what the issue is.
Old Aug 23, 2011 | 10:17 PM
84-6.9L's Avatar
84-6.9L
It my be low on refrigerant and icing up on you. Have you check your pressures at all?
Old Aug 24, 2011 | 09:20 PM
mhancock2's Avatar
mhancock2
Oh yes I have checked the refrigerant and it is where it needs to be. Maybe a little high, but still it what is concidered normal operating range.
Old Aug 24, 2011 | 10:03 PM
farmert's Avatar
farmert
Did you open up the heater box when you first fixed the blend door? If not take the cover off and check it out. Some times a pencil or something simular will fall threw the defrost vents and wedge in by the blend door, not allowing the door to shut completely.
Old Aug 25, 2011 | 03:47 AM
tjc transport
i ain't rite
and more often the insulation around the door gets old and falls apart letting hot air mix with the cold
Old Jul 30, 2025 | 06:33 AM
Scott Bostwick's Avatar
Scott Bostwick
4wd Low
Originally Posted by mhancock2
I have cold air!!!! Ok I put my daughter to bed and decided that I am going to fix this. I took the controls out and saw the cable. I pulled the glove box out and tucked back in there i saw the white ****. I flipped it and there was cold air. So know I need to locate where to by the replacement cable but for now I have cold air. My daughter will be pleased, she is 20 months old and she sweats in her car seat so badly. Thanks everyone for your help. We both appreciate it.
I think I am having the same issue with my 2012 F250. Can you give me more specifics on what you did?
Old Jul 30, 2025 | 07:11 AM
Olds64's Avatar
Olds64
Hopefully @tjc transport can move your post to the appropriate forum. I doubt a 2012 truck has much similarity to earlier trucks.
Old Jul 30, 2025 | 11:24 AM
mf7lakes's Avatar
mf7lakes
Plus the thread is 14 years old
Old Jul 30, 2025 | 02:31 PM
tjc transport
i ain't rite
and the op has not logged on in over 13 years.
he would be better off just starting a new thread in the proper forum.
MorrisClan
May 14, 2015 05:36 PM
jayro88
Aug 4, 2013 01:23 AM
merlynr
Apr 8, 2010 10:52 AM
crazyyake
Aug 19, 2005 10:57 PM
MRB068
May 13, 2002 06:57 AM
