Wierd Lean Cylinders?
Old Aug 6, 2011 | 03:34 PM
71 Sport Custom's Avatar
71 Sport Custom
Any idea why a 352 would burn lean on the rear 4 holes. Motor is rebuilt and have checked all the standard stuff. Thanks
Old Aug 6, 2011 | 03:36 PM
ford390gashog's Avatar
ford390gashog
Which cylinder numbers?? Or is it both rear two cylinders on each side???
Old Aug 6, 2011 | 04:16 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
2v or 4v ? Stock intake or aftermarket ? 2 hole Plenum or 4 hole plenum or dual plenum ? single plenum ? all will act different...depending on usage...
Old Aug 6, 2011 | 06:37 PM
71 Sport Custom
Its the two rears on each side. 66 vintage. Iron 4v intake. Holley 4v carb. Had to jet up. Front four plugs read good. four rears look really lean.
Old Aug 6, 2011 | 07:05 PM
RapidRuss's Avatar
RapidRuss
How lean is real lean..white lean ..or light tan lean... you might have to jet up more depending on how you drive it ? until you get a happy medium..no sooty looking color but yet a darker tan if its in all cyliners.. also check the float level in the back bowl..it may need to be raised..you do know the right way to check for proper burn on the plugs right ? you need to run it up to say almost redline on your motor..and shut it off , with your foot off the throttle...
Old Aug 7, 2011 | 07:58 AM
Argess's Avatar
Argess
I had a similiar issue, but the other way. I had 4 cylinders running rich. I forget whether it was the front 4 or back 4 now. But anyway, could it be you actually have your front 4 running rich and the back 4 are OK?
In my case, I had an internal leak in the carb.
By the way, here's a pretty good link of how to read plugs:
Spark Plug Reading
Old Aug 7, 2011 | 09:37 AM
71 Sport Custom
Ordering a new carb for now.
stealth1
52
Jul 14, 2015 05:59 PM
brbuchanan
Jun 11, 2015 12:27 PM
jmikeyj4
Oct 22, 2010 01:02 AM
dtherren
May 10, 2006 12:02 AM
spurredon
24
Sep 18, 2004 12:02 AM
