clutch hard
Old Aug 6, 2011 | 02:31 AM
stevenjakeryan's Avatar
stevenjakeryan
clutch hard
Gday everyone , Have a clutch pedal issue in my 77 , its changing gear ok with no noise or grinds and no reasons to be concerned before , but after parking on a steep hill (nose down) i found pedal wouldn go all the way in when i tried to engaged to reverse out and the pedal was harder than a boiled egg. Any ideas on what it could be , master cylinder 3/4 full , it feels like somethings jammed up. Could it be slave cylinder stuck.
Old Aug 6, 2011 | 03:19 AM
73f250highboy's Avatar
73f250highboy
Need some info.... Engine.. trans.. Whatcha got?
Old Aug 6, 2011 | 07:32 AM
stevenjakeryan
clutch issues
motors a 351c with a 4 spd toploader and a 9" diff , very stock truck , ok what ever the issue was , it has now fixed itself ....still got me stumped as to what caused it. I did pump and pump clutch trying to free it up and made no difference until i had to move it out of driveway and when i switched engine off clutch pedal went down and back up and it was normal
Old Aug 6, 2011 | 02:24 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are you Australian or Kiwi?
Josh
Old Aug 6, 2011 | 03:30 PM
73f250highboy
Oddd I didn't think these trucks came with a hydrolic clutch or a 351c
Old Aug 6, 2011 | 03:35 PM
ford390gashog's Avatar
ford390gashog
Master cylinder , slave cylinder 351c????? I am very confused. In the states these trucks came with none of those.
Old Aug 6, 2011 | 03:49 PM
73f250highboy
My thoughts exctally
Old Aug 6, 2011 | 05:38 PM
stevenjakeryan
clutch issue
Yeh im Aussie , we had 6 cyl , 302 and 351"s here with auto and manual.I have been told my trucks Canadian imported minus running gear and told all that was added here most likely
Old Aug 7, 2011 | 12:03 AM
Bullitt390's Avatar
Bullitt390
May not have anything to do with the clutch, master or slave, but more to do with the throwout interferring with pressure plate fingers somehow.
The best thing to do is bleed the clutch line.
Verify the firewall isn't flexing or cracked behind the clutch master.
Make sure the slave is contacting the clutch arm correctly.
Josh
Fordbronco69
Oct 31, 2012 02:00 AM
Ariela
18
Dec 27, 2011 10:21 PM
Motorhead351
16
Aug 12, 2005 09:35 AM
patuca
Oct 29, 2003 10:04 PM
fordff
Jul 18, 2002 08:14 PM
