Motor doesn't start...?
Old Aug 8, 2011 | 05:18 PM
7283-F250's Avatar
7283-F250
I know you checked the firing order but did you check to make sure the rotor was at cyl 1 when it is supposed to be.
I bought my '68 from a chebby guy who told me he replaced the points. I pulled all the wires and replaced them. Than it took me forever and the hard way to find out he put the dist in backwards (180 deg out) and than proceeded to run the plug wires to match "his" way of installing the dist. Truck ran fine when I bought it and drove the hour home with no issues. If you pulled all the plug wires off I would check that.
Old Aug 15, 2011 | 03:48 PM
Biggi's Avatar
Biggi
That's exactly what it was. Pulled the distributor and set it the right way, was 180 degrees of. Also had to reset the points. Plugged all the wires back in and it started right up. Runs good now. Thanks everybody for your help. Ready to hit the road now....
Old Aug 15, 2011 | 07:14 PM
7283-F250's Avatar
7283-F250
Glad to see you it got it running and if wasn't too big of a problem.
Cris Molina
31
Jun 16, 2019 02:17 PM
Lolo77
Feb 14, 2015 06:57 PM
Binkowski
Jun 30, 2014 03:53 PM
Inline6Rookie
Jul 23, 2013 10:20 PM
saezjose
Bronco II
Jan 18, 2010 04:31 PM
