E4OD shifting problems
Old Aug 5, 2011 | 06:35 PM
Bear Creek Majors's Avatar
Bear Creek Majors
Hi guys, I have a problem with my E4OD. I have a 94 F250, 7.3 turbo 4X4 with 230K. I bought it several years ago with maybe 200K. The previous owner told me the kid he bought it from had the trany worked on or replaced, I would have to guess at about 150 to 175K. It has always been a little bit of a head jerker when shifting, but if I mash the skinny pedal it runs through the gears great.
So a while back it had no reverse one day, checked the fluid, a little low, toped it off and problem gone. Then a week or two later I was towing a tractor home on the trailer….In OD…(probably the root cause of my problems) and the OD light starts flashing, drove it the rest of the way home in drive. Thinking that I just ran it hot I reset the computer, dropped the pan and changed the oil. The old oil wasn’t black but it had a funny smell, not really a burnt clutch smell, and it was a dark red. The bottom of the pan was relatively clean.
Now I have shifting problems, reverse kicking in/out, and major hesitation between gears and then a hard head jerking shift. Pulled the codes last night and had a 14, PIP failure in the continuous memory, (ignition profile pickup circuit failure), as it is a diesel I thought it was garbage and cleared the memory. Drove it to work today, had everything from slush box shifts to head jerker’s depending on what I was doing, OD on/off, slow accelerating, mashing the skinny pedal, and none of the problems consistently in any particular gear. Got the OD light blinking again and checked the codes when I got home. Again got the PIP, and a code 62, trans 4/3 circuit fault. I think I got this one while winding it out between D & OD.
Last night I checked the plug connection at the neutral safety switch (forgot the correct abbreviation), checked the trans plug, it looked like it may have been a little wet but it didn’t look corroded, blew it out, gooberd it up with dielectric grease but still had the problems today.
TC seems to be locking up OK.
Thinking about throwing together a breakout box to see if the SV’s are firing when they are suppose to, but I’m really thinking it’s a TC or valve body problem.
Any Ideas?????
<O></O>
Pat
Old Aug 6, 2011 | 04:34 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't know what SV's are so I can't help you there.
Code 62 means there is slip. I don't know where you got a "trans 4/3 circuit fault" description, nor do I have any idea what a "trans 4/3 circuit" is.
Usually a code 62 happens from a bad torque converter. The converter clutch apply piston tends to crack, allowing apply pressure to leak past the piston. A new converter will fix this.
Old Aug 6, 2011 | 06:40 AM
Bear Creek Majors
Sorry Mark, SV is the industrial term for solenoid valve, I need to stick with automotive terminology on this board!
My dime store code reader has this 4/3 circuit fault listed in the book for code 62, apparently I need to call someone in Taiwan to tell me what it means.
I’m by no means a trans expert but I’m thinking I have to agree with you, I don’t believe its control issues, the fact that the problems are in all gears and not even consistently the same all the time, and the fact that it’s been a slow & jerking shifter as long as I have owned it kinda makes me think it’s not clutches or valve body but the TC.
<O</O
I’ll start calling on prices this morn.
<O</O
Ok, next issue. Is there a vender that sells the clutch disks for the double disk clutch rather than having to dish out the bucks for a complete rebuilt unit? 92 F350 4X4, 7.3 non turbo.
<O</O
Pat
Old Aug 6, 2011 | 06:48 AM
Bear Creek Majors
By the way Mark, where are you at? I have a place kinda between Old Town and Cross City.
Pat
Old Aug 6, 2011 | 07:30 AM
Mark Kovalsky
I'm near Ocala.
If you mean torque converter clutch disks, yes, you can buy them, but you don't want to. I suspect they only sell large quantities and you have to have the equipment to bond the material to the steels. Plus you have to cut the converter open and weld it back together.
Old Aug 6, 2011 | 10:05 AM
Lazy K's Avatar
Lazy K
If you mean a disc for the stock dual mass flywheel in a manual trans F350 then rockauto.com should have one as should many others.
J.Amato
17
Sep 15, 2018 06:16 PM
uniboy95
Jul 31, 2018 08:27 AM
sidecardonnie
Aug 21, 2017 12:03 PM
dtrujillo63
May 19, 2011 06:17 PM
jdemaris
30
Aug 9, 2007 12:40 AM
