Any idea where to get replacement fuel lines for a '96 F350 4x4, 7.3l E4OD. The rear lines, forward and return, to the rear tank need to be completely replaced. They have the quick clips at the ends of s.s. braided lines.
I'm pretty sure that LMC has them....they'll list as 1980-86 but from what people tell me they're the same for our gen trucks. I'm in the same boat as you (also in CT) and need to replace the lines on my '96 really soon!
Roger
I actually have a 84 with totally different lines and connections. I've been searching but even the Ford parts sites don't seem to have them. These lines have those metal clips inside the end of the line connections. Speaking of which, anyone know where to get a whole sending unit assm. for this truck? It has no pump on it, just the sender, tubes, one yellow wire, and the connector on the outside. Can't seem to locate one of these either... thanks!
Steve
Sorry, I'm actually looking for parts for the '96 7.3l. My '84 is complete(the only truck that is). I've tried everything in my area, NPD, LMC, Bronco G.Y.. No luck. I guess I'm on to junkyards.... Thanks though!
The sending unit is easy enough to find... The hard part is the hanger, the part # is f6tu-8275-da. That was on the sticker atop the hanger assm. Can't find them anywhere. I also need the fuel lines associated with it that go up to the selector valve.
