aod tv pressure
Old Apr 1, 2003 | 11:58 AM
camarokid81's Avatar
camarokid81
aod tv pressure
i am having problems setting tv pressure on my 1991 e150 van 5.0 efi trans is rebuilt and so is converter have new tv cable what is the best pressure to set it at looking for someone who has set up a few of these trannies i have the pressure at 36 psi and wondering if to high of pressure will damage this trans trans has 15 miles on it i`am using a cloths pin between the tvcable crimped end and the throtle bodty piviot for a guage it mesures 5/16 have 24000 lb cooler and radiator hooked up no kinks in the lines no leake all new fluid and system has been flushed twice idle is 650 rpm in neutral when i am setting trans and engine runs real good help from someone who has set a few of these up would be great thanks for reading sorry it is so long just dont want to smoke this trans
Old Apr 1, 2003 | 04:39 PM
rprice's Avatar
rprice
aod tv pressure
I recently rebuilt an AOD in a '93 F-150. I used the procedure from the factory service manual: with engine fully warmed up and in neutral, the TV pressure should be 33 +/-5 psi with the gauge installed just as you described and zero (no more than 5 psi) with the gauge removed at idle. The service manual does not give the thickness of the gauge, but the guys at Ford Racing measured one for me and it was .276" , so your 5/16" clothespin is a bit over but not too bad!
A slightly high TV pressure will not damage the trans, the shifts will just be late and a bit harsh. Sounds like you are close.
Ron
LARIAT 85
'80-'86 HOWTO's
34
Jun 6, 2026 11:08 PM
Slave2tattoos
Apr 20, 2015 11:20 PM
Flat Ernie
19
Jan 22, 2015 06:57 PM
Irelands child
All Things Towing
Nov 17, 2014 10:04 AM
camarokid81
Apr 25, 2004 07:03 PM
