Coolant temp sensor, info needed, gauge not working
Ok guys, let me bring you up to speed on where I am at diagnosing this thing.
I've checked the plug -- verified with the DVM that ground and power wires are correct. Put a DVM to both pins, it's showing 12 volts.
I ohmed the sensor -- it's got absolutely no resistance.
Got a brand new sensor -- put it in some boiling hot water, hooked up the plug, still no reading on the dash. Ohmed the new sensor and it's completely open too.
Took a 470 Ohm, 5W resistor and bridged the two pins on the plug -- dash gauge read near normal.
Now, after doing all that, I'm thinking the wiring is fine since the dash gauge moved with the resistor bridged across the pins. What I don't know is, what's the correct voltage to the sensor? I was thinking it should be 5V, not 12V.
Also, I'm wondering what the resistance range should be on the sensor? It seems to me that it shouldn't be completely open, but my old one, which was working fine in the 7.3, and the brand new one I got today both showed open. I'm guessing it's possible that the new sensor is bad out of the box.
Any thoughts here, or anyone know the correct voltage to the sensor and resistance through the sensor?
Thermostat—Electrical Test
CAUTION: Always vent the exhaust to the outside when performing this test.
NOTE: The electrical thermostat test is most accurate if performed indoors at less than 37.8°C (100°F) ambient air. This test may be performed with or without the hood open and with the engine warm or cold.
Check the engine coolant level. Fill as needed.
With the ignition OFF, remove the engine coolant temperature (ECT) sensor harness connector and attach ECT Sensor "T" Cable as a jumper between the powertrain control module (PCM) (12A650) and the ECT Sensor. Attach the 73 Digital Multimeter to the ECT Sensor "T" Cable. Voltage values (0-5 V) may now be monitored while the sensor retains its connection to the wiring harness.
A scan tool or the Service Bay Diagnostic System (SBDS) may be used to monitor the ECT on vehicles equipped with data link connector (DLC). The SBDS sequence to use for the screen is: Toolbox-Electronic Engine Control and DCL-Item.
NOTE: Running this test with the vehicle in gear or with the A/C compressor clutch engaged (running) will cause incorrect diagnosis.
Place the transmission in PARK (P) or NEUTRAL (N).
Start the engine and allow the engine to idle throughout this test. Allow the engine to run for two minutes, then record the ECT voltage. Record the ECT voltage every 60 seconds. When the ECT voltage trend changes direction or only changes slightly (0.03 volt or less) from the previous reading, record this as the thermostat opening voltage. Use the voltage and corresponding coolant temperature chart listed below.
Coolant Temperature °C (°F) ECT (Volts)
22 (71) 3.00
43 (109) 2.01
71 (159) 1.01
82 (180) 0.75
91 (195) 0.059
97 (206) 0.050
105 (221) 0.040
If the thermostat opening voltage is greater than 0.75 volt and less than 88°C (190°F) on 5.4L engines or 82°C (180°F) on 6.8L engines, install a new water thermostat.
If the thermostat opening voltage is less than 0.75 volt and greater than 82°C (180°F), the water thermostat is good and should not be replaced. Refer to the Symptom Chart for further instructions.
linky to manual page
Two things that I'm needing to know from a truck that has a properly functioning ECT circuit are: 1)resistance value in the sensor, if any, and approximate temp. 2) Voltage across the female pins on the plug, with the key in the on position.
If the sensor is only supposed to receive 5 volts, and mine is getting 12, I've got something askew.
That makes me feel a lot better. 12V is normal across the pins. There should be resistance of some type across the sensor. That's what I needed to know.
Looks like both of my sensors are bad. I'll take the new one back tomorrow...and take the DVM with me to the parts store to be sure another new one isn't faulty. I think Kris is going to send me one though, so I may just wait for that one to get here.
It's looking to me like my gauge is reading higher temps with less resistance and more voltage to the signal wire. I have no idea what would cause this, or where to even begin looking. Hopefully you guys have some ideas, because I'm completely lost again.
on my '00 the stupid thing has two positions: about 450 ohms and shorted at 250 ish degrees, could be more, but this is what I observe, and I can't verify the temps while running
I am looking at about 8/9 volts running to the gauge with heat coming out the passenger heater, coolant temp unknown. the only time the @#$^&* needle moves is when it is really hot outside and I'm running the Ac up the side of a mountain dragging the trailer. then it just kinda jumps to HOT which annoys the pcm enough to de-fuel somewhat.
I'm thinking you have a bad sensor even though it is brand new. you could always wire a variable resistor into the signal line and adjust it to reflect what the heater outlet see's
