SPEEDO IS OFF ??
Old Aug 5, 2011 | 11:47 AM
Teds's Avatar
Teds
SPEEDO IS OFF ??
put gps in the truck today and noticed the gps showed me 3mph slower than speedo..it has the 265/75 on it...why would she be off...
w that being said does than mean my odo is showing more miles i have driven or less miles(as far as checking fuel mileage)
Old Aug 5, 2011 | 11:57 AM
joe blow's Avatar
joe blow
Anything larger than a stock tire (not sure what that is) will affect the speedometer. Superlift has a speedo correction which I dont think is worth the money. Just be cognizant of the change. As for fuel mileage....not sure how to help you on that one
Old Aug 5, 2011 | 12:09 PM
npccpartsman's Avatar
npccpartsman
You'll find that the speedo needle is off compared to reading the vehicle speed sensor digitally by about 3 mph but that the odometer is actually VERY close. Mine has been like that since new and mine came with 265-75-16's also.
Old Aug 5, 2011 | 12:12 PM
dchamberlain's Avatar
dchamberlain
LT265/75R16 is one of the stock tire options on his 2003.
If your GPS will read miles driven, use it to check the odometer. There is a decent chance the odometer is right.
As I understand it, the Fed requirement is that speedo's can read a little high but not a little low, so automakers err on the side of high. Even if it is effecting the odometer, it's probably not enough to really notice.
Old Aug 5, 2011 | 02:12 PM
Rusty Axlerod's Avatar
Rusty Axlerod
The error will increase with speed since both devices agree at "0". If GPS is correct and speed o is off, you are not traveling as far/fast as speedo displays. So odo shows more miles than actual.
If ur 3mph off at 60mph, error is .05 ( not significant)
GPS can have errors also.
Old Aug 5, 2011 | 03:02 PM
Misky6.0's Avatar
Misky6.0
On my Ex with stock-size tires 265.75.16 I have
the same thing.
Lots of threads that 285.75.16 tires make the
speedo "dead on" but they also cause lowered MPG.
Well, if you change tire size all the computer
calculations are effected so everything will be
different - "real" MPG might actually be the SAME, but
now the computer thinks you didn't go as far thus
less miles/gallon would not be surpising, but did you
really drive less miles??? Even hand calculating,
if the odometer is wrong your by hand math won't be accurate either.
Amazingly, when I fill-up (40-44 GAL) my SGII is within 1 or 2 TENTHS of a
gallon @ how much fuel I actually take. I'd trust the SGII vs. dash.
Old Aug 5, 2011 | 04:34 PM
npccpartsman
If I read MPH on the Scangauge II digitally it's dead on with GPS but the speedometer needle is 2.5mph higher. The odometer has always agreed with GPS calculated mileage almost exactly.
Rumble phish
2004 - 2008 F150
Jun 5, 2019 04:12 PM
weskan
Aug 15, 2014 08:44 PM
Djphelan01
Apr 12, 2013 07:07 PM
bryyce62
Feb 22, 2008 01:56 PM
V10KLZZ71S
Sep 5, 2003 06:47 AM
