Sponsored by: Real Truck
Speedo/odometer ??
Old Feb 22, 2008 | 01:30 PM
bryyce62's Avatar
bryyce62
Speedo/odometer ??
Does anybody know if the speedometer and odometer are run off the same sensor? ('03 F250 16" rims all stock wheels & tires)
The reason that I ask is; based on my new GPS, my speedo is off by 3mph @ 60mph. Can I assume that if my speedo is low by, say 5%, my total vehicle mileage would be off by the same ratio?
gw
Old Feb 22, 2008 | 01:36 PM
bruno6491's Avatar
bruno6491
im interested in this as well
Since my tires are slightly off then the stock ones, does that add mileage to the truck if they are slightly bigger or less mileage?
Bruno
Old Feb 22, 2008 | 01:41 PM
bryyce62's Avatar
bryyce62
It's all about rotation. One rotation of a bigger tire will go farther than a smaller tire. Your gas mileage will calculate worse than acutal, due to the bigger tire. The speedo will show that you are going slower that you actually are.
What I want to know is if the two components (odo/speedo) are both controlled by the same sensor.
gw
Old Feb 22, 2008 | 01:47 PM
skoveng's Avatar
skoveng
I believe the speedo and odo do use the same sensor along with the anti-locks, it is located at the top of the rear diff housing and uses the tone ring fixed to the diff.
Old Feb 22, 2008 | 01:51 PM
rbaker6336's Avatar
rbaker6336
that might depend on the truck,with 4R100 speedo works off output shaft sensoe OSS on rear of transmission
Old Feb 22, 2008 | 01:56 PM
skoveng's Avatar
skoveng
True. If it is a 6.0 it would be in the rear.
