Sponsored by: Real Truck
speedo correct?
Old Sep 4, 2003 | 09:26 AM
V10KLZZ71S's Avatar
V10KLZZ71S
speedo correct?
Does 265-75r tires change my speedo any compared to stock 235,s?
Old Sep 4, 2003 | 10:25 AM
97expy5_4's Avatar
97expy5_4
speedo correct?
You shouldn't be running 235's on the X. They all come with 265's, unless you might have bought it used.
PS.... I could be wrong though....
Big Mick
Old Sep 4, 2003 | 10:51 AM
swampfox35173's Avatar
swampfox35173
speedo correct?
Check out the stats on tirerack.com for tire dimensions. It lists tire diameters and other stuff. You can see if the larger width also increases the diameter. I doubt there is much of a diff in diameter between 235s and 265s. Best way to double check is run a measured mile at 60 mph (if you can bear to go that slooow). At 60mph, the mile will take exactly 1 minute. If it takes less, you speedo is reading low, if more than 1 minute, speedo is reading high. Hope this helps.....
Old Sep 4, 2003 | 03:02 PM
Autobahn F-250 Lariat's Avatar
speedo correct?
Check out this website it has your answers
http://www.mgbexperience.com/misc/tirecalc.html
Old Sep 4, 2003 | 04:30 PM
V10KLZZ71S's Avatar
V10KLZZ71S
speedo correct?
Thanks autobahn, my original tire were 31.72 inches, compared to 31.64 inches. The speedo calculater deal came out to be nothing worth worrying about. thanks
Old Sep 4, 2003 | 06:36 PM
99f350sd's Avatar
99f350sd
speedo correct?
235's and 265's are no where near the same size..
Unless the 235's were 85 series
Old Sep 5, 2003 | 06:34 AM
V10KLZZ71S's Avatar
V10KLZZ71S
speedo correct?
Thats what i originally had 235/85,and now have 265/75.I thought that the 265,s were taller, but the 235,s are taller according to the chart on that website. only 8/10th,s of an inch,
Old Sep 5, 2003 | 06:47 AM
99f350sd's Avatar
99f350sd
speedo correct?
The 235's are usually smaller the 85 series isn't that popular.
