power steering moan..
I blew the power hose apart a couple of months ago on the road. had to walk to an auto parts store and buy a new hose. I asked if my truck took a special power steering fluid. He said NO.. just use regular PS fluid. luckily i had my tool box behind my seat.
I pulled the inner fender and cooler tube off on the side of the road and changed the hose. I guess as i removed the small fitting from the power box, the bigger fitting moved and ripped the O-ring behind it and developed a slow leak. I drove it for about an hour and it finally stopped moaning. I rechecked and filled it, As i started my drive back home. 2 hr. Because of the slow leak, it started moaning again, I stopped to refill and on my way again. got home and posted it on here. You all said I needed to flush and use Motor craft AFT. I ran three quarts through it and refilled.
its been about two months and most of the moan has gone, but there is still a Low constant moan.. Do you guys think my Power box is on its way out now ??
thanks.. phil
EDIT: I just saw that you have a PSD. Did you pump the breaks and turn the wheel while you did the flush? The hydro boost stores some fluid under pressure so you have a pump of the brakes if the truck dies.
