Sponsored by: Auxito
Transmission Squeek? really?
Old Aug 4, 2011 | 10:44 PM
Justin16's Avatar
Justin16
I'm lost. I'm no expert on tranny's at all but I've never heard of one squeeking. Mine squeeks (worse if I'm accelerating) in all gears, including reverse. Doesnt seem to do it in nuetral. I tracked it to the tranny by jacking up the back tires, turning the driveshaft by hand and following the noise. Its not a continous sound but sounds like everytime something turns it squeeks at a certain point. I flushed the tranny fluid and changed the filter made no difference. I believe its the 4r70. 2000 F150 4x4 Any ideas? Thanks ahead of time.
Old Aug 5, 2011 | 02:06 PM
Bluegrass 7's Avatar
Bluegrass 7
If you turned the drive shaft and hear it, it's the output shaft seal or U-joint related on the ends of the driveshaft.
Old Aug 5, 2011 | 06:58 PM
Justin16's Avatar
Justin16
If it were the U-joints wouldn't there be some slop in the driveshaft? any advise on how to narrow it down? thanks for the help
Old Aug 5, 2011 | 09:07 PM
Bluegrass 7
Come on Justin, get under there and work on it.
Might try to use some spray lube on the U joints and see it it changes it at all.
All there is is the slip yoke on the trans and it's seal, front U joint and the rear U joint.
Good luck.
Old Aug 6, 2011 | 09:29 AM
Justin16's Avatar
Justin16
I'm gonna try replacing the U joints here in a little while and hopefully that'll take care of it. Thanks
Gigemags05
15
Oct 12, 2014 07:25 AM
jsparrow
Sep 11, 2009 02:50 PM
duggyb
1997 - 2003 F150
Oct 27, 2007 12:18 PM
ken's 80
Jan 23, 2007 11:21 AM
tamarackstyle
Apr 12, 2004 08:36 AM
