tjbeggs rear disk conversion
Old Aug 6, 2011 | 05:41 PM
fordpride's Avatar
fordpride
I can get those free. Off to the junk yard this week
Old Aug 6, 2011 | 08:36 PM
joe_13894's Avatar
joe_13894
Originally Posted by wildstang
Superduty is Same setup.
yes, only our wheels won't fit the axle.
Old Aug 6, 2011 | 08:38 PM
Talyn's Avatar
Talyn
Yeah. I like my rims. I dont want the extra expense of buying those either. =\
Old Aug 6, 2011 | 09:53 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
I wonder how much it would be to have axels made to fit the superduty rear but drilled to our lug pattern?
Another possible option that I have heard Is to use a dana 70 or 80 from a Dodge truck with rear disks.
Old Aug 6, 2011 | 09:55 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
A guy that won the diesel power challenge put on by diesel power magazine had a 97 f350 cummins powered truck with a Dana 80 in it. I'm not sure if it was disk brakes though.
Old Aug 6, 2011 | 10:09 PM
fordpride's Avatar
fordpride
I think he is talking about taking the calipers and all mounting hardware of the SD and put on the OBS
Old Aug 7, 2011 | 10:10 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
That's what Tim did but had to cut his old mounting flanges off and weld on new ones.
Old Aug 7, 2011 | 11:42 AM
tjbeggs's Avatar
tjbeggs
Yep building the SD axle flange was a breeze compared to building the chevy caliper mounts. And if you can burn in a weld good and use your brain them doing the super duty calipers is the way to go over the chevy set up. One of these days I need to do a better write up on the SD brakes and take some better pictures of my axle.
Old Aug 7, 2011 | 12:43 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Pictures would help a lot.
Old Aug 7, 2011 | 12:44 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
The e brake is the hang up for me
Vermont requires them for yearly inspection.
Old Aug 7, 2011 | 05:21 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Been considering this as well,have an extra dana 80 and might put under the f350 as the original axle has some noise from the carrier and just about shot.Would be nice to be able to bolt the f350 hubs onto the rotors to keep the same wheels/rims.Never use a parkin brake either,wheel chocks are more effective so i always bring some wood blocks with me.
Old Aug 7, 2011 | 05:51 PM
bad12jr's Avatar
bad12jr
Dodge hubs are the same pattern as obs hubs. 8 on 6.5 pattern.
Old Aug 7, 2011 | 05:56 PM
  #28
wildstang's Avatar
wildstang
VT Chapter Ldr
Sounds like you have a Dodge dana 80 with disk brakes. What year Dodge had them? Is your truck auto? Is there a plug in on the pumpkin for the vehicle speed sensor?
Old Aug 7, 2011 | 11:49 PM
  #29
MONAVIERONJON
This one is from a 92 super duty 10 lug,i believe is a dana 80,same as on a 97 fsuper duty with a vss,seems like the gearing would be a little slower for fuel mileage though,sorry for the hijack,just got me thinkin
Old Aug 8, 2011 | 08:03 AM
  #30
Talyn's Avatar
Talyn
if I could get a driveshaft brake that functions, I'd not complain about parking brake.
I"ve just heard driveshaft brakes are to problems.
