it is getting colder out now where i live and the exhaust is getting steamy
i have true duals on my truck but only one side steams
sometimes both sides steam but why is it that just the one sode steams sometimes
Steam, from what I understand, appears due to the condensation of water in the exhaust system upon the cool-down process. If, for whatever reason, one side of your exhaust was routed differently, the cool-down rate between the two sides could differ. Condensation may have more of a chance to accumulate in a faster, or slower, cooling exhaust (though I can't say which it would be).
That being said, I seem to have remembered that H2O is a byproduct of internal combustion engines... read this excerpt from a web page:
"A hydrocarbon fuelled internal combustion engine such as a petrol or diesel engine is inherently “dirty” by virtue of its operation. All hydrocarbon fuels produce carbon dioxide (CO2), carbon monoxide (CO) and water vapor (H2O) as byproducts of combustion. The more complete the combustion process, the more C02 and the less CO. CO is poisonous to humans at certain concentrations and considered a major contributor to environmental pollution."
http://216.239.53.100/search?q=cache:76-TFXkUTHQC:www.steamcar.co.uk/Challenge/Home_Page.htm+byproducts+internal-combustion-engines&hl=en&ie=UTF-8
In taking that one step further, perhaps a cylinder, or bank of cylinders (which would then depend on the head and the intake manifold's design problems), is burning better/worse than the other?
If your system isn't leaking coolant at any rate into the cylinders (which it probably isn't - but that's hard to rule-out sometimes), then I, too, would like to know the physics behind this phenomenon that I have seen on other true-dual exhaust systems.
I think it also has to do with the length of pipe. Since the entire system is cold in the morning, if 1 pipe is longer than the other, it has a longer cold pipe to go through, therefore the temp drops more and thus creates more condensation I think.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
its not really a big deal i was just wondering why
its been buggin me to see the steam (as i describe it) to be comming out of one tail pipe and not the other
my exhaust is all the same length on both side give or take 2 inches
i did notice a leak at the joint of the muffler maybe that is why
its new so im gonna take it back and have it fixed up
when the engine is cold, the exhaust gets routed through the intake to help warm the motor. then when the engine warms, the valve which diverts it through the intake closes, and it goes through the exhaust pipe. im not sure what the valve is called, possibly th EGR valve (exhaust gas recirculation).
