Sponsored by: Real Truck
OBD 2
Old Aug 4, 2011 | 12:40 AM
wcook1967's Avatar
wcook1967
OBD 2
Have a 2005 F350. OBD 2 not working and neither is lighter. Checked #12 fuse it is good? Wires look fine. Any ideas? Want to go camping but cant reprogram my truck to tow mode from performance. Have a Diablo Trinity.
Old Aug 4, 2011 | 06:57 AM
projectSHO89's Avatar
projectSHO89
You'll have to repair the lighter circuit since the OBDII port is on the same circuit.
Old Aug 4, 2011 | 09:07 AM
dchamberlain's Avatar
dchamberlain
Did you just inspect the fuse visually or did you check it with a test light or meter? A fuse can be bad but not appear burned. Also check to make sure the fuse socket is tight. If all of those are OK then you have to have a broken wire somewhere.
Old Aug 4, 2011 | 10:58 AM
wcook1967's Avatar
wcook1967
Tested fuse with multimeter its ok. If I run a new 12v power fused to the lighter will this repair the obd2 as well? That provided I can not find bad wire
coyw
2004 - 2008 F150
Mar 7, 2019 11:57 PM
CharlieA1
Modular V10 (6.8l)
Aug 25, 2013 12:53 PM
quietman
Mar 21, 2013 09:06 PM
Danny Stroup
Electrical Systems/Wiring
Feb 3, 2010 06:16 PM
kms910
May 27, 2004 02:56 AM
