plz help
Old Mar 4, 2019 | 04:49 PM
coyw's Avatar
coyw
plz help
New so not to sure and to find stuff but I sure could use the help.
I bought a 2007 f 150 v6 and figured out that my opd port cigar lighter and 12 volt outlet don't work, checked fuse 110 and is good still don't work. I checked continuity all is good. any help at all would be greatly appreciated thanks
Old Mar 4, 2019 | 08:05 PM
Fifty150's Avatar
Fifty150
If it is a fuse, you will want to check fuse #41, or fuse #110. It all depends on your truck. Some trucks use 41. Some trucks use 110.
Old Mar 5, 2019 | 02:11 PM
steve(ill)'s Avatar
steve(ill)
did you pull 110 and replace it, or just look at it ? Check power to the pin on one side ?
Old Mar 5, 2019 | 04:22 PM
coyw's Avatar
coyw
replaced it and yes I have power on one side, I love the truck but dang lol. I also have tested the wire coming out of fuse box for the cigar obd2 port and it is not hot even with a jumper wire in fuse 110 spot. so I pulled a hot with in line fuse from bat and tied into the cigar lighter but still no luck on obd port. could a bad ground be in play here?
Old Mar 5, 2019 | 06:55 PM
Fifty150's Avatar
Fifty150
Check fuse 41. On some trucks, it's fuse 41.
2007 Ford F150 Fuse Diagram ? Ricks Free Auto Repair Advice Ricks Free Auto Repair Advice | Automotive Repair Tips and How-To
1 10 Windshield wiper motor, Instrument Cluster (IC), Audio Control Module (ACM)
2 20 Indicator flasher relay, Brake pedal position switch
3 7.5 Exterior rear view mirror switch, Seat adjust switch, Driver Seat Module (DSM)
4 10 Rear Entertainment Module (RETM), Power folding mirror module
5 7.5 Powertrain Control Module (PCM), Autolamp/sunload sensor, Climate control assembly, HVAC module, EATC
6 15 Main light switch, Vehicle Security Module (VSM)
7 5 Audio Control Module (ACM)
8 10 Climate control assembly, HVAC module, EATC, Exterior rear view mirror, driver side, Exterior rear
view mirror, passenger side
9 20 Fuel pump relay
10 20 Trailer tow relay, parking lamp, Trailer tow relay, reversing lamp
11 10 A/C clutch relay, Integrated wheel ends solenoid
12 5 PCM power relay
13 10 Climate control assembly, HVAC module, EATC, Indicator flasher relay, Heated rear window relay,
Front blower motor relay, Trailer tow relay, battery charge
14 10 Digital Transmission Range (DTR) sensor, Daytime Running Lamps (DRL) relay, Deactivator switch,
A/C high pressure switch, Heated Positive Crankcase Ventilation (PCV) valve, Anti-lock Brake
System (ABS) module, Reversing lamps switch, Auxiliary relay box 1
15 5 Floor shifter, Overdrive cancel switch, Instrument Cluster (IC), Traction control switch
16 10 Brake pedal position switch
17 15 Fog lamp relay
18 10 Parking Aid Module (PAM), Electronic compass, Electrochromatic inside mirror unit, Heated seat module, driver side front, Heated seat module, passenger side front, Vehicle Security Module (VSM), Auxiliary power point
19 10 Occupant Classification System Module (OCSM), Restraints Control Module (RCM)
20 10 Auxiliary power point
21 15 Instrument Cluster (IC)
22 10 Audio Control Module (ACM), Roof opening panel switch, Door lock switch, passenger side, Door lock switch, driver side
F23 10 Headlamp, right
24 15 Battery saver relay
25 10 Headlamp, left
26 20 Horn relay
27 5 Passenger Air bag Deactivation (PAD) indicator, Instrument Cluster (IC)
28 5 Passive anti-theft transceiver module, Powertrain Control Module (PCM), Fuel pump diode
29 15 Powertrain Control Module (PCM)
30 15 Powertrain Control Module (PCM)
31 20 Audio Control Module (ACM), Satellite Digital Radio Receiver System (SDARS) module
32 15 EVAP canister purge valve, A/C clutch relay, Charge Motion Control Valve (CMCV), Valve cover assembly, left, Heated Oxygen Sensor (HO2S) #11, Heated Oxygen Sensor (HO2S) #21, Manifold Absolute Pressure/Intake Air Temperature (MAP/IAT) sensor, Positive crankcase ventilation heater, EGR system module, Variable Camshaft Timing (VCT) valve 1, Variable camshaft Timing (VCT) valve 2, Intake manifold Tuning Valve (IMTV), Camshaft position sensor, Electronic fan clutch
33 15 Digital Transmission Range (DTR) sensor, Daytime Running Lamps (DRL) relay, Deactivator switch, A/C high pressure switch, Heated Positive Crankcase Ventilation (PCV) valve, Anti-lock Brake System (ABS) module, Reversing lamps switch, Auxiliary relay box 1
34 15 Powertrain Control Module (PCM)
35 20 Fog lamp relay, Daytime Running Lamps (DRL) relay, Headlamp, right, Headlamp, left, Instrument Cluster (IC), Fog lamps, Main light switch
36 10 Trailer tow connector, Park/stop/turn lamp, right rear
37 20 Power point, console 1, Power point, console 2
38 25 Subwoofer
39 20 Power point, Instrument panel
40 20 Daytime Running Lamps (DRL) enable relay, Vehicle Security Module (VSM), Main light switch, Multifunction switch
41(1) 20 Data Link Connector (DLC), Cigar lighter, front
42 10 Trailer tow connector, Park/stop/turn lamp, left rear, Multifunction switch Fuse Amps Circuits protected
101 30 Starter relay
102 20 Ignition switch
103 20 Anti-lock Brake System (ABS) module
105 30 Trailer electronic brake control module
106 30 Trailer tow relay, battery charge
107 30 Trailer electronic brake control module
108 30 Trailer tow relay, battery charge
109 30 Adjustable pedal switch, Seat adjust switch, driver side front, Driver Seat Module (DSM)
110(1) 20 Data Link Connector (DLC), Cigar lighter front
111 30 Clockwise (CW) motor 4×4 relay Counterclockwise (CCW) motor 4×4 relay
112 40 Anti-lock Brake System (ABS) module
113 30 Windshield wiper motor
114 40 Heated rear window relay
115 20 Roof opening panel module
116 30 Front blower motor relay
117(1) 20 Power point Instrument panel
118 30 Heated seat module, driver side front, Heated seat module, passenger side front
401 30 CB power sliding window switch, rear, Roof opening panel module, Master window adjust switch, Window adjust switch, passenger side
Old Mar 5, 2019 | 07:56 PM
coyw's Avatar
coyw
thanks for the diagram but fuse41 is a blank in my fuse box. almost think it a faulty fuse box\
Old Mar 6, 2019 | 12:51 PM
pdqford's Avatar
pdqford
How did you check the continuity?
And when you checked continuity did you have fuse #110 removed?
How many ohms between the non-powered side of the fuse receptacle to pin #16 of the DLC?
Old Mar 6, 2019 | 04:13 PM
coyw's Avatar
coyw
I checked from dlc pin 16 to fuse 110 and got nothing then from pin 16 to the wire coming out of fuse box and all was good, dropped it off at ford this morning and they called with the problem, bad fuse box. he said that was common for them to go bad. luckily the carlot I got it from has agreed to pay for it do the air bag light being on when I bought it, so I will post if that is the fix. I thank everyone that has to the time to heip.
Old Mar 6, 2019 | 05:14 PM
pdqford's Avatar
pdqford
Good job! Since you had continuity from the LB/WH wire at the fuse box to pin 16 of the DLC, that pin points the problem within the fuse box. If that was the case, I was gonna suggest pulling the fuse box, flipping it over and check the fuse 110 contacts for green stuff (trademark :-)
I guess it’s too late now.
Old Mar 6, 2019 | 07:25 PM
Fifty150's Avatar
Fifty150
It's common for fuse boxes to go bad? That's news to me. We're always learning something new.
Old Mar 7, 2019 | 06:41 PM
coyw's Avatar
coyw
yep now ford is saying its discontinued lol. go figure anyways thanks for all the
Old Mar 7, 2019 | 11:57 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Not common like it happens on half of them, but I've seen a lot of them here in the short time I've been a member so far.
quietman
Mar 21, 2013 09:06 PM
materthegreater
Mar 16, 2012 09:05 AM
Danny Stroup
Electrical Systems/Wiring
Feb 3, 2010 06:16 PM
ntputter17
Mar 14, 2009 10:56 PM
kms910
May 27, 2004 02:56 AM
