more e4od questions
Old Aug 4, 2011 | 12:36 AM
bikeymikey's Avatar
bikeymikey
more e4od questions
can a clogged filter cause the tranny to slip?
Old Aug 4, 2011 | 05:15 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If the filter is clogged the transmission has failed. That's the only way to get enough junk in the filter to clog it.
Old Aug 4, 2011 | 08:21 AM
bikeymikey's Avatar
bikeymikey
thanks. can you shed some light as to why the mechanic at the transmission shop told me to go change the filter? this was after i had told him that i dropped the pan, drained the torque converter and replaced the fluid with merconIII/dextron. he asked me what color was the old fluid and if it smelled burnt. i said black and no. he says: "you dropped the pan and you didn't change the filter? why didn't you change the filter?". i told him that i needed the truck later that day and couldn't wait for the auto part store to order the right one. so he tells me: "well the lines are flushed, drop the pan and change the damn filter!"
Old Aug 4, 2011 | 10:50 AM
Mark Kovalsky
It may be clogged. If your fluid was black there is a good chance the trans is toast.
Many people, including some trans shops, insist on always changing the filter. Ford doesn't recommend changing the internal filter except when the transmission is rebuilt.
1happycamper
Apr 12, 2018 08:44 AM
1L243
16
Jun 25, 2016 09:25 AM
MY1STCREW
2004 - 2008 F150
46
Feb 20, 2009 12:50 AM
hink10
Aug 6, 2006 11:58 PM
str400ex
Jan 27, 2005 07:19 PM
