Brake pedal vibrates when at a stop
99 F350, auto, 4x4. Today my brake pedal started vibrating when I am pressing on it at a stop (traffic light, stop sign, etc). Feels like it's giving my foot a massage. My pads/rotors are almost new and brake fluid is full.
Do I have a problem with my hyrdoboost? What should I look for??
Could be an isue anywhere in your belting system, ie pulleys. I would take your belt off to start, make sure idler pulley isnt loosing a bearing, same with tensiononer pulleys. Also your AC clutch could be slipping causing the surging, your power steering pump is what drives brake boost, so if anything in that loop is loose or failing, you wil feel it in the pedal.
And like yourself, I have newer pads and rotors.
Mine problem turned out to be that I had a broken belt in my front tire.
I found it when I rotated my tires.
I replaced my tires, and now the truck rides like a new one and no more foot massage when I step on the brake pedal.
Let us now what you find and good luck.
texastech_diesel
11-23-2009 10:31 PM
live2hunt
08-17-2007 09:10 PM
