Sponsored by: Real Truck
Fix exhaust flaring
Old Aug 3, 2011 | 07:46 AM
Tmill's Avatar
Tmill
Fix exhaust flaring
I have a exhaust leak on my 2003 F250 V10 4x4. It is were the manifold connects to the y-pipe. I guess the y-pipe is a dealer only part that's around $400ish. Is it possible to recondition the flared end of the y-pipe without replacing it? Or could I cut the y-pipe, weld on a new flared end?
Trav
Old Aug 3, 2011 | 12:18 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You can get a new ypipe that is more efficient.
Old Aug 3, 2011 | 04:58 PM
Tmill's Avatar
Tmill
So replacing it would be the best move then?
Old Aug 3, 2011 | 04:59 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
That would be my guess. A lot of guys report a big improvement with an aftermarket ypipe.
Old Aug 3, 2011 | 09:11 PM
Tmill's Avatar
Tmill
Aftermarket from the dealer or an outside manufacture?
Old Aug 3, 2011 | 10:03 PM
Zedrive's Avatar
Zedrive
This should help you see what you'll choose to do.
Ford Truck Enthusiasts Forums - View Single Post - Is a Y-PIPE a must have?
Remember to Rep the original contributers.
Old Aug 3, 2011 | 10:48 PM
dkf's Avatar
dkf
There are no aftermarket complete Y-pipe replacements to my knowledge.(Not without replacing the manifolds) The aftermarket y-pipes are just a small section that replaces the necked down portion of the stock y-pipe. Most well equipped exhaust shops can flare exhaust pipe to mate to the ball connector flange on the stock exhaust manifolds. These trucks are also known to snap exhaust manifold studs that can cause an exhaust leak so make sure there are no exhaust leaks at the manifolds from broken studs. Headers like from Banks and Doug Thorley replace the stock exhaust manifolds and the entire y-pipe up to the triangular flange right before the cat. That is another option.
Old Aug 4, 2011 | 06:52 AM
Tmill's Avatar
Tmill
I guess I will have to take it to the shop to have someone who knows more then me look at it. I just hope it doesn't cost me my first born son!!!
Capt. Rick
Sep 23, 2017 12:40 PM
Truck Guy99
Aug 29, 2013 12:20 PM
jarch
Exhaust Systems
Apr 17, 2005 12:26 AM
popkorn
Mar 6, 2005 01:50 PM
