AOD swap question
Old Aug 2, 2011 | 03:44 PM
skynyrdcat's Avatar
skynyrdcat
AOD swap question
I've got an 86 F150 302 with a AOD that's lost OD.
I have an 87 Cougar donor car that's got an AOD also, just wondering if it would be a direct swap?
If not, how difficult would it be to match up a 4 or 5 speed?
I've never been a fan of automatics anyway.
skynyrdcat's Avatar
skynyrdcat
By the way, the cougar has a 302 as well.
Old Aug 2, 2011 | 05:27 PM
Franklin2's Avatar
Franklin2
Good question, I have never swapped a AOD. I do know from swapping other trannies, even if you have the exact same model(c4 for a c4, c6 for a c6, etc) that there can be different lengths and different arms where the shifter lever hooks up. The arms are usually swappable, but you have to take the tranny pan and the valve body loose.
So the first thing I would do is compare the lengths of both trannies. Of course your truck would have to be a 2wd to even consider a car tranny working.
Old Aug 2, 2011 | 07:48 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If the length is the same and yours is 2wd, all you may have to change is the manual lever on the trans.
Old Aug 2, 2011 | 09:35 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
One thing to be very careful with, the TV cable, the one from the throttle body to the transmission outer lever. It is NLA I have been told. Adustment is critical and is probably why yours lost OD.
Old Aug 3, 2011 | 07:14 AM
skynyrdcat's Avatar
skynyrdcat
Thanks for the info guys...
My Grand Pa always had trouble with the trans in this truck. He even had it rebuilt a few yrs before he passed away and the OD didn't last long after that. It sat for 3yrs after he passed, until I got it to restore and now I'm learning a lot about the notorious AOD! LOL
It is a 2wd by the way.
Thanks again.
northeaster79
Jan 16, 2010 09:29 AM
Eddiec1564
Bronco II
Dec 13, 2009 04:12 PM
RP27G8G
Oct 23, 2006 09:43 AM
gordo351
Jan 12, 2005 05:37 PM
wot302
Engine Swaps
Nov 11, 2004 03:33 PM
