f250 probs
Old Aug 2, 2011 | 12:36 PM
msckksm's Avatar
msckksm
f250 probs
I have a 1990 f250 diesel, the oil pressure gauge drops to zero when the check engine dummy lght comes on and I also notice the rpm gauge does not stay up it drops to zero as well . What is going on?
Old Aug 2, 2011 | 01:00 PM
powerstroke72's Avatar
powerstroke72
Moved to the Pre-Power Stroke Diesel (7.3L IDI & 6.9L) forum.
Old Aug 2, 2011 | 01:11 PM
Phy's Avatar
Phy
Did these symptoms start at the same time? Recently?
It sounds suspiciously like an instrumentation/wiring problem, though my tach did that & was the tach sender...
I'd check the cab ground strap first. Lotsa weird things can happen with a bad ground...
If you don't find anything obvious, I'd try to get a mechanical oil pressure gauge to install temporarily & verify the oil pressure.
Old Aug 2, 2011 | 01:16 PM
msckksm's Avatar
msckksm
250 probs
I do not know if the problems are connected just noticed them. The main problem is the oil pressure gauge takes a dive only when the check engine light comes on. I will check grounds and electrical first Thanks, Mike
Old Aug 2, 2011 | 01:46 PM
GHeTTo JOe's Avatar
GHeTTo JOe
i think the check engine might come on when oil pressure is less than ~7??
Old Aug 2, 2011 | 06:15 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Don't rely to much on that gauge anyways..... there borderline useless!
Old Aug 2, 2011 | 09:45 PM
tecgod13's Avatar
tecgod13
Yup, I want to say thats the ONLY time the check engine light will come on in these trucks. So the check engine light is doing what its supposed to do if the oil pressure gauge drops to 0. Generally speaking, the gauge is just a fancy looking idiot light for most of these trucks. The sender is just an on or off at 7 PSI or so. Some of the earlier trucks with 6.9L's had real pressure senders, but the later trucks were switched to on/of senders.
Seeing that the tach is dropping at the same time, I'd say check the grounds, and other wiring under the dash and see if anything might be rubbing or shorting out.
Old Aug 3, 2011 | 03:37 AM
tjc transport's Avatar
tjc transport
i ain't rite
is there oil in the engine?
Losman33
Mar 22, 2016 05:38 PM
BURNSTOUGHFORD
Nov 22, 2009 04:52 PM
phillips91
Aug 19, 2009 07:38 AM
jeremy53402
Jul 13, 2008 07:30 PM
greyantaylor
Dec 2, 2003 10:59 PM
